Question about Tuner
Old Oct 11, 2006 | 04:38 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
Default Question about Tuner
Hey guys any recommendations on what tuner I should buy? This is for a N/A 350Z with all boltons including mrev2 +5/16 spacer, intake, headers, exhaust, pulleys. Was looking in the Apexi SAFC II but is there anything else that most Z owners use? Thanks
Old Oct 11, 2006 | 04:41 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
If you can wait a couple of days, I'll show you some progress with Greddy EU. If you ask me this is a great tuning solution for N/A.
UTEC is definitely better but takes a little bit more effort.
By the way please browse around this forum (tuning forum) because doing independent research is the only way you'll ever make an informed decision on tuning.
Old Oct 11, 2006 | 04:56 PM
pony_killer
Arada ninda apa
how much did the greddy eu run you? see i was looking at the safc II because i wanted to get a custom install in my sunglass holder. thought it would look cool =]
Old Oct 12, 2006 | 11:21 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I got the greddy EU with complete harness wired to an autosport harness (makes it plug and play) for about $700 ish. It was used, from another member on the forums.
New it will run you a bit more than that.
UTEC runs a bit more than the EU once you get everything you need to go with it.
I have it mounted using some tough velcro down underneath the passenger side dash, all the way up against the right wall of the car.
I also got the cipher tool from AAM for about $400, which lets you tap into the factory widebands and get an accurate air/fuel ratio without purchasing an aftermarket wideband. (as well as datalog everything you ever needed to know about what the car's doing)
issyz
Jul 2, 2017 03:04 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
35reilly
Sep 28, 2015 07:42 AM
