UTEC map selector question
Old Nov 15, 2006 | 05:22 PM
Midnyte's Avatar
Midnyte
Default UTEC map selector question
I just mounted the UTEC remote map selector switch, but have a question. I understand that the molex plug goes to the UTEC, but what about the red wire (i'm guessing its for a remote solenoid if needed)...black is obviously a ground but I dont know about the other 2 flying leads. It says they are for something for the clutch, but i would assume that's if I bought the shift light. It came with a jumper, should i short them...or just tuck them away.
Thanks in advance...
Old Nov 16, 2006 | 05:46 AM
Nic@CiNcity's Avatar
Nic@CiNcity
You are correct. Ground the black, just tuck the red. It's for a spare solenoid.
Those other two leads you are asking about aren't used. Just tuck that away. I called TurboXS and verified with Sharif about this very thing. It explains in the manual what this is for.
Old Nov 16, 2006 | 10:51 AM
Vader007's Avatar
Vader007
It was my understanding that the red wire was for the clutch saftey switch?
issyz
Jul 2, 2017 03:04 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
