Kind of Confused
Old Nov 30, 2006 | 10:21 PM
macehowling's Avatar
macehowling
Default Kind of Confused
Is an engine management system, reflashing the ECU? Just software tuning?
Old Dec 1, 2006 | 04:25 AM
QuadCam's Avatar
QuadCam
itis a hardware solution that integrates with the Stock ECU.
I can comment on the UTEC as that is what I have.
I doesn not alter or change the stock ecu. at your predetermined parameters (user settable), the UTEC takes over control of fuel and timing...giving you absolute control of injector pulsewidth and ignition timing degrees relative to TopDeadCenter. SOme other units only deal with offsets of whatever the stock ecu is doing.
Old Dec 1, 2006 | 10:18 AM
macehowling
So, I noticed a lot of engine management system tuning solutions and not much mention of actually reflashing the ECU. Is reflash the ECU not a common practice with our Z? Does the engine management system offer better gains? What are the benefits?
Old Dec 1, 2006 | 02:35 PM
QuadCam's Avatar
QuadCam
the biggest need for an EMS is the abiltiy for the EMS to utilize a MAP sensor.
Our ECU doesn't have a MAP sensor as it uses the MAF meter to tell the engine what is going on.
Technosquare does a good job on their reflash units on the turbonetics kit, but if you up the boost (or overboost) beyond what technosquare flashed the ECu to do, you will be out of luck.
On my UTEC, I have the ability to shut off the fuel flow if I overboost. this is accomplished through the MAP sensor.
this is a simplistic answer. you should read the UTEC manual on the www.turboxs.com website. It'll give you a great idea about what a piggyback controller can do.
Old Dec 1, 2006 | 03:57 PM
macehowling
Great, thanks!
lolwatbro
Oct 9, 2021 04:58 AM
ddegrande21
Sep 6, 2015 11:15 AM
