Vortech @ 7psi, how lean can i go?
Old Dec 18, 2006 | 05:24 PM
RA11325's Avatar
RA11325
Default Vortech @ 7psi, how lean can i go?
Been street tuning, got my A/F to 11.0 in the midrange and high 10's at redline, how much leaner can i go?
Old Dec 18, 2006 | 06:03 PM
charged's Avatar
charged
Old Dec 18, 2006 | 07:21 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
for a street tune, I wouldnt go much past what you have.
Old Dec 19, 2006 | 05:05 AM
QuadCam's Avatar
QuadCam
your intake air temps are probably very good with the vortech and an intercooler. you could run a 7 psi setup non-intercooled most likely on these motors.
what I am getting at is you don't need to drown your mixture with fuel. on a vortech, you probably are making more than 5 psi below 5500 rpms, right? You can easily have you air:fuel in the 12s (and making nice power!) in the lower rpms (less boost). Scale your A:F so that it gets fatter as boost increases.
Start at about 12.8:1 for 1psi and fatten it up as you go in psi. in your case, psi and rpm run together. by the time you reach full boost (around 6000 rpm), you will probably want your ratio to be 12:0 - 11.5:1.....that you will need to experiment with.
When you get it al down, you will have really nice throttle repsonse......much better than just setting it to hold a solid 11.5:1 all the way. on a centrifugal blower, your boost response is linear......so should your A;F ratio be.
Old Dec 19, 2006 | 05:33 AM
Julian@MRC's Avatar
Julian@MRC
I would keep her very low 11's. 11.3 tops..you can run a bit leaner on the SC's going in to boost up to about 4500rpms.
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
