My first FI log. Help me out guys.
Old Dec 20, 2006 | 02:09 PM
Nic@CiNcity's Avatar
Nic@CiNcity
Default My first FI log. Help me out guys.
Scroll to post #5 for a full .txt file download.
Ok. Just got done with my first 100% throttle pull in 4th gear. My BOV spring wasn't tight enough, so i only hit about 5 psi. I don't have my boost controller hooked up so that i can run stock WG boost for the time being. It's 30 degrees out, 92 octane, 52 psi on the CJ fuel return. Let me know if you need any more info and what i need to do next. Thanks guys. I've been talking to alot of you and i thank you guys for everything. Notice all my knock i'm getting from early in the RPM.. WTF?
2827 -11.4 1.86 9 00 00 1.61 +32.5 3.7 ECU. +0.0 1.74 13.28
2463 -10.3 3.39 34 00 00 6.53 +31.3 16.6 ECU. +0.0 3.19 13.81
2128 -4.3 3.35 49 00 00 9.09 +27.4 16.2 ECU. +0.0 3.09 13.65
2201 -0.7 3.21 59 00 00 9.08 +24.6 16.9 ECU. +0.0 2.96 12.83
2278 -0.5 3.19 61 00 00 8.76 +22.3 16.2 ECU. +0.0 3.00 11.92
2276 -0.3 3.25 64 00 00 8.50 +20.2 15.7 ECU. +0.0 3.03 11.11
2262 -0.1 3.35 65 00 00 8.54 +18.4 16.0 ECU. +0.0 3.09 10.90
2335 +0.0 3.35 65 00 00 8.52 +17.4 16.3 ECU. +0.0 3.09 11.28
2344 +0.3 3.37 65 00 00 8.54 +14.4 16.4 ECU. +0.0 3.13 11.76
2362 +0.4 3.41 65 00 00 8.68 +14.4 17.1 ECU. +0.0 3.19 12.06
2413 +0.6 3.54 65 00 00 8.64 +15.3 17.2 ECU. +0.0 3.25 12.30
2436 +1.0 3.54 68 10 00 9.41 +14.3 19.1 +20.5 +0.0 3.29 12.49
2538 +1.3 3.58 73 10 23 9.73 +10.5 20.8 +17.5 +0.0 3.33 12.42
2472 +1.5 3.58 73 10 03 9.63 +11.1 20.3 +17.5 +0.0 3.41 12.25
2544 +1.9 3.64 78 20 00 9.93 +11.4 20.9 +17.5 +0.0 3.39 12.21
2608 +2.2 3.70 79 20 10 10.36 +11.5 22.5 +17.0 +0.0 3.45 12.17
2649 +2.4 3.74 80 20 01 10.71 +11.3 24.2 +16.4 +0.0 3.54 12.25
2666 +2.8 3.76 81 30 05 11.36 +10.2 25.4 +16.2 +0.0 3.47 12.37
2681 +3.0 3.82 83 30 05 11.81 +12.3 26.2 +16.0 +0.0 3.58 12.14
2763 +3.3 3.94 86 30 00 12.43 +12.3 28.6 +15.6 +0.0 3.60 11.87
2791 +3.5 3.90 86 30 00 12.54 +13.3 29.3 +15.3 +0.0 3.56 11.53
2822 +4.0 3.86 88 40 00 12.92 +12.4 30.4 +16.8 +0.0 3.60 11.20
2876 +4.3 3.96 92 40 08 13.17 +14.4 31.4 +14.9 +0.0 3.70 11.05
2891 +4.4 3.98 95 40 08 13.47 +14.2 32.3 +14.2 +0.0 3.76 10.89
2957 +4.7 4.07 100 40 00 13.61 +16.4 33.3 +13.9 +0.0 3.66 10.86
2957 +4.8 4.11 102 40 00 13.70 +15.3 34.4 +13.7 +0.0 3.80 10.80
3003 +4.9 4.07 102 40 00 13.88 +17.3 35.3 +15.5 +0.0 3.82 10.78
3044 +5.0 4.15 102 40 00 13.98 +16.3 36.1 +15.3 +0.0 3.86 10.80
3112 +5.0 4.13 103 40 00 14.13 +17.2 36.5 +15.2 +0.0 3.90 10.80
3126 +5.0 4.19 102 40 00 14.32 +16.2 37.7 +15.0 +0.0 3.90 10.80
3183 +5.1 4.19 102 40 01 14.54 +16.2 38.7 +14.8 +0.0 3.90 10.78
3220 +5.0 4.19 103 40 01 14.68 +15.3 39.5 +14.6 +0.0 3.92 10.68
3239 +5.0 4.25 103 40 00 14.80 +16.3 40.2 +14.5 +0.0 3.94 10.62
3323 +5.0 4.27 102 40 00 14.84 +16.2 41.5 +14.3 +0.0 3.98 10.55
3394 +5.2 4.27 102 40 00 14.89 +15.3 41.5 +14.2 +0.0 3.98 10.49
3397 +4.9 4.29 103 40 00 14.93 +15.2 42.2 +14.0 +0.0 4.07 10.48
3436 +5.1 4.33 103 40 00 14.96 +16.2 42.8 +13.8 +0.0 4.01 10.48
3486 +5.0 4.39 103 40 00 14.99 +15.3 43.7 +13.7 +0.0 4.05 10.52
3538 +4.9 4.39 102 40 00 15.11 +15.2 44.3 +13.5 +0.0 4.03 10.53
3584 +5.0 4.41 103 40 00 15.28 +16.2 45.9 +13.5 +0.0 4.07 10.55
3615 +5.0 4.39 103 40 00 15.43 +16.1 47.1 +13.5 +0.0 4.09 10.55
3642 +5.0 4.41 102 40 00 15.52 +16.2 47.1 +13.5 +0.0 4.11 10.55
3679 +4.9 4.45 102 40 00 15.77 +16.1 48.7 +13.5 +0.0 4.15 10.52
3770 +4.8 4.47 102 40 00 15.89 +16.2 49.6 +13.4 +0.0 4.11 10.49
3800 +5.1 4.56 102 40 00 15.96 +16.1 50.5 +13.3 +0.0 4.17 10.46
3858 +4.9 4.54 103 40 00 16.01 +16.1 51.7 +13.4 +0.0 4.23 10.43
3866 +5.1 4.56 102 40 00 16.02 +16.1 52.0 +13.3 +0.0 4.25 10.34
3907 +4.9 4.56 101 40 00 16.09 +16.2 52.5 +13.3 +0.0 4.17 10.27
3954 +5.0 4.54 102 40 00 16.16 +16.1 53.2 +13.4 +0.0 4.21 10.26
4016 +5.1 4.60 103 40 00 16.23 +16.3 54.1 +13.4 +0.0 4.25 10.23
Old Dec 20, 2006 | 02:10 PM
Nic@CiNcity
The rest.
4040 +5.1 4.68 102 40 00 16.23 +16.0 54.7 +13.4 +0.0 4.35 10.24
4105 +4.9 4.62 101 40 00 16.25 +16.2 55.3 +13.3 +0.0 4.31 10.26
4120 +4.9 4.70 103 40 00 16.24 +16.1 55.7 +13.4 +0.0 4.41 10.27
4177 +4.9 4.68 103 40 00 16.23 +16.0 56.0 +13.4 +0.0 4.35 10.29
4224 +5.0 4.70 103 40 00 16.23 +15.0 56.8 +13.3 +0.0 4.41 10.31
4268 +4.8 4.80 102 40 00 16.24 +15.1 57.4 +13.4 +0.0 4.31 10.33
4284 +4.9 4.68 103 40 00 16.25 +15.1 57.8 +13.5 +0.0 4.41 10.36
4340 +5.0 4.78 102 40 00 16.33 +12.9 59.1 +13.4 +0.0 4.37 10.36
4391 +4.8 4.80 103 40 00 16.35 +13.7 60.3 +13.4 +0.0 4.49 10.36
4409 +4.8 4.72 102 40 00 16.37 +14.0 60.0 +13.4 +0.0 4.43 10.33
4432 +4.8 4.90 102 40 00 16.46 +13.0 61.3 +13.4 +0.0 4.45 10.27
4528 +4.8 4.80 102 40 00 16.50 +12.8 61.9 +13.4 +0.0 4.43 10.26
4668 +4.9 4.78 102 40 00 16.51 +14.0 62.1 +13.5 +0.0 4.43 10.23
4597 +5.0 4.84 102 40 00 16.52 +13.8 62.4 +13.4 +0.0 4.37 10.20
4591 +4.9 4.92 101 40 00 16.52 +14.3 63.6 +13.4 +0.0 4.41 10.20
4662 +4.9 4.98 102 40 00 16.51 +14.1 64.0 +13.4 +0.0 4.43 10.15
4681 +4.9 4.92 103 40 00 16.51 +13.9 64.3 +13.4 +0.0 4.37 10.20
4728 +4.9 4.96 101 40 00 16.51 +13.9 65.0 +13.4 +0.0 4.50 10.21
4782 +5.0 4.94 102 40 00 16.43 +13.8 65.2 +13.5 +0.0 4.49 10.17
4810 +5.0 4.98 103 40 00 16.26 +14.1 65.0 +13.6 +0.0 4.47 10.20
4830 +5.0 4.94 103 40 00 16.16 +16.0 65.2 +13.7 +0.0 4.50 10.23
4887 +5.1 5.00 102 40 00 15.96 +15.9 64.6 +14.0 +0.0 4.49 10.26
4930 +5.0 4.98 101 40 00 15.78 +15.0 64.5 +14.1 +0.0 4.54 10.33
4952 +5.1 4.94 102 40 00 15.64 +16.0 64.6 +14.3 +0.0 4.52 10.43
5232 +5.0 5.00 102 40 00 15.53 +16.0 64.8 +14.4 +0.0 4.54 10.55
5035 +5.1 5.00 102 40 00 15.60 +15.1 65.5 +14.5 +0.0 4.54 10.65
5089 +5.1 5.00 102 40 00 15.71 +14.9 66.8 +14.5 +0.0 4.54 10.73
5096 +5.0 5.00 102 40 00 15.84 +14.1 67.3 +14.5 +0.0 4.54 10.74
5175 +5.1 5.00 102 40 00 15.98 +14.0 68.7 +14.5 +0.0 4.54 10.73
5200 +5.1 5.00 103 40 00 16.07 +15.0 69.8 +14.5 +0.0 4.54 10.68
5232 +5.2 5.00 101 40 00 16.21 +17.1 70.6 +14.5 +0.0 4.58 10.65
5291 +5.1 5.00 101 50 00 16.33 +17.0 72.0 +14.6 +0.0 4.58 10.62
5359 +5.1 5.00 102 40 00 16.30 +17.9 72.7 +14.7 +0.0 4.58 10.58
5350 +5.1 5.00 103 50 00 16.43 +17.8 73.5 +14.8 +0.0 4.58 10.53
5376 +5.1 5.00 102 50 00 16.52 +18.0 74.0 +14.8 +0.0 4.58 10.52
5455 +5.1 5.00 102 50 00 16.64 +17.8 75.1 +14.9 +0.0 4.58 10.46
5482 +5.2 5.00 103 50 00 16.71 +17.9 76.1 +14.9 +0.0 4.58 10.43
5509 +5.3 5.00 103 50 00 16.78 +17.8 77.0 +15.1 +0.0 4.58 10.39
5555 +5.2 5.00 101 50 00 16.76 +17.9 77.6 +15.0 +0.0 4.58 10.36
5592 +5.1 5.00 101 50 00 16.71 +17.9 78.0 +15.0 +0.0 4.58 10.33
5640 +5.0 5.00 103 50 00 16.58 +17.8 78.0 +15.1 +0.0 4.58 10.31
5668 +5.2 5.00 102 50 00 16.59 +18.0 78.1 +15.0 +0.0 4.58 10.31
5727 +5.2 5.00 101 50 00 16.53 +17.9 78.5 +15.0 +0.0 4.58 10.31
5727 +5.2 5.00 102 50 00 16.51 +17.9 79.1 +15.0 +0.0 4.58 10.31
5767 +5.3 5.00 102 50 00 16.49 +17.8 78.8 +14.9 +0.0 4.58 10.33
5807 +5.1 5.00 102 40 00 16.38 +17.7 79.4 +15.1 +0.0 4.58 10.34
5837 +5.2 5.00 102 40 00 16.37 +18.7 79.8 +15.1 +0.0 4.58 10.36
5868 +6.6 5.00 102 50 00 17.81 +18.8 87.3 +15.1 +0.0 4.58 10.40
5910 +5.3 5.00 101 50 00 16.34 +18.9 80.8 +15.2 +0.0 4.58 10.39
5952 +5.2 5.00 101 50 00 16.30 +18.6 80.9 +15.1 +0.0 4.58 10.40
5973 +5.2 5.00 102 50 00 16.41 +18.7 81.9 +15.3 +0.0 4.58 10.40
6027 +5.1 5.00 101 50 00 16.27 +18.9 81.2 +15.3 +0.0 4.58 10.40
6093 +5.2 5.00 102 50 00 16.27 +18.9 82.0 +15.3 +0.0 4.58 10.43
6071 +5.2 5.00 101 50 04 16.27 +18.9 82.5 +12.6 +0.0 4.58 10.43
6105 +5.2 5.00 102 50 00 16.27 +19.0 83.3 +12.6 +0.0 4.58 10.43
6161 +5.3 5.00 101 50 00 16.31 +18.7 83.3 +14.5 +0.0 4.58 10.43
6184 +5.3 5.00 101 50 00 16.27 +20.8 83.6 +14.6 +0.0 4.58 10.48
6207 +5.3 5.00 101 50 00 16.31 +20.9 84.4 +14.6 +0.0 4.58 10.45
6242 +5.3 5.00 101 50 00 16.31 +21.0 84.7 +14.8 +0.0 4.58 10.42
6277 +5.3 5.00 101 50 00 16.31 +20.8 85.6 +14.3 +0.0 4.60 10.30
6313 +5.4 5.00 102 50 00 16.31 +20.8 85.0 +14.6 +0.0 4.60 10.21
6301 +5.3 5.00 101 50 00 16.31 +21.8 85.7 +14.6 +0.0 4.60 10.20
6373 +5.4 5.00 101 50 00 16.31 +21.9 86.2 +14.6 +0.0 4.60 10.15
6385 +5.3 5.00 101 50 00 16.31 +21.8 87.0 +14.5 +0.0 4.60 10.23
6325 +5.4 5.00 102 50 00 16.36 +21.8 86.7 +14.6 +0.0 4.60 10.20
6385 +5.4 5.00 101 50 00 16.31 +21.7 87.2 +14.6 +0.0 4.60 10.12
6422 +5.4 5.00 102 50 00 16.36 +21.9 87.8 +14.5 +0.0 4.60 10.09
6497 +5.4 5.00 102 50 00 16.36 +22.7 88.7 +14.5 +0.0 4.60 10.06
6459 +5.4 5.00 102 50 00 16.31 +22.8 88.0 +14.5 +0.0 4.60 10.04
6535 +5.4 5.00 102 50 00 16.36 +22.8 88.8 +14.5 +0.0 4.60 10.01
Old Dec 20, 2006 | 02:11 PM
Nic@CiNcity
I tried the code tags and it still wouldn't let me go over 10,000 characters. I had a few more RPM's to post above and below, but cut them out trying to get under 10k. Oh well, i think this will work for now. Any advise will be helpfull.
Let me know if i should post my base map for further disection. I know i'm super rich and remember someone telling me to turn down the fuel preasure, but i'm not sure that's the best option?
Old Dec 20, 2006 | 06:09 PM
Kenk2's Avatar
Kenk2
Professional
Attach the Log TXT file to your post so we can d/load it..
Yea right off the bat, you are a little rich..
Old Dec 20, 2006 | 06:20 PM
Nic@CiNcity
Not sure what all that stuff is at the bottom? I just noticed that. You can see where i get knock counts prior to going WOT. Anyone know why that might be?
Old Dec 20, 2006 | 06:43 PM
Kenk2's Avatar
Kenk2
Professional
First thoughts after quickly going over the log..
I have not tuned a car that is FI.. I would think at that PSI you could be safe at around 12.5 or so.. I think your running pretty rich.. Try taking away some fuel from 2750 all the way to 7000.. DO a 'block' edit and do like -1.5
Your timing I wouldn't worry about right now nor the knocks early on.. you are not at full 100% TPS.. Get your fuel dialed in, then worry about your timing...
What seems odd to me is that you never really get above 50 in the load column...You are peaking at 50 which seems odd.. Like I said I have not tuned FI before so maybe someone who is will chime in here shortly..
Old Dec 20, 2006 | 06:46 PM
Kenk2's Avatar
Kenk2
Professional
Could be engine noise, could be knocks.. your timing is set like +5 over stock in that area.. YOu might want to dial it back a little bit and see if that helps..
Its also a good idea to get multiple logs.. Good long runs at WOT from 2500 RPM to bouncin off the rev limiter.. Try and get 2 or 3 and post them all here.. We can then try and get some kind of look at how the car is reacting to what your doing right now and see how consistent it is.. I know its tough out on the highways with traffic too but....
Old Dec 20, 2006 | 06:49 PM
Nic@CiNcity
I was wondering about the load column as well. Other FI logs i've seen are in the 90's.
Old Dec 21, 2006 | 07:36 AM
Nic@CiNcity
Some have mentioned that because my boost is so low and my map was intended for use @ 8psi, that'd be why i'm SO rich. Sounds about right. Last night i tightend up my BOV spring so that i could at least hit the Greddy stock WG pressure (around 6ish i think?). I'll post a log here in a bit and we'll see what happens to my AFR's. They "should" lean out a little bit.
Old Dec 21, 2006 | 07:42 AM
Kenk2's Avatar
Kenk2
Professional
Right on...
If you cant get up to 8psi then we will just have to adjust your fuel to accomodate..
Old Dec 22, 2006 | 06:19 AM
Kenk2's Avatar
Kenk2
Professional
Bump for updates..
Did you get any more logs??
Old Dec 22, 2006 | 07:56 AM
Nic@CiNcity
Did not get a chance to log. After tightening up my BOV, i punched it once and still wasn't boosting over 5. I think i'm going to try hooking up my boost controller to get me to 6-7psi. The COLD weather here leaves me so unmotivated to do anything
Old Dec 22, 2006 | 08:03 AM
Kenk2's Avatar
Kenk2
Professional
I hear that.. Az. has been pretty damn cold (40-ish) and I need to get my Tanabe lowering springs on the G...
Old Dec 27, 2006 | 03:21 AM
Nic@CiNcity
I did get a few more logs, but i'll have to post those later today. With a little timing adjustment, i all but eliminated all that knock that kept showing up pre 3k RPM's. I'll still see 1 count of knock in places and just wanted to verify that was acceptable. Is 1 count here or there anything to really worry about? Of course no knock would be best and will be achieved as i progress in my tuning, but can i rest easy for a bit with 1 count showing up a few times in a couple hard pulls from 3rd-4th gears??
We're supposed to see snow this week, so i'll have plenty of time to hook up my boost controller as well. Still only seeing about 5.5 psi. Before i mess with my fuel, i'd like to raise the boost a bit to lean it out that way. Thanks for looking. I'll be back.
Old Dec 27, 2006 | 05:20 AM
Kenk2's Avatar
Kenk2
Professional
Yea 1 knock count I wouldnt be worried about NA, but FI... I am unsure..
+1 on the boost controller.. Get that in and you might lean out a bit at higher psi.. keep me posted
jlb
Oct 15, 2017 05:10 AM
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
sherm
Sep 10, 2015 11:02 PM
LA-Z
Mar 21, 2003 11:21 AM
