ECU information needed, flashes, upgrades ect... Please =)
Old Feb 12, 2007 | 12:16 PM
VtotheZ's Avatar
VtotheZ
Default ECU information needed, flashes, upgrades ect... Please =)
Just wondering if I could get some information on all this ECU talk, I did a search and read a few things about the AAM ECU reflash. Seems exspensive for what you get... What exactly do they do? Can we do it our selves or do you need a special computer/software?
What is the most popular one being used right now, for NA non rev Z's?
Sorry to be so confused, but I dont know much about the ECU flashes and what not, wanted to good information, I have read a few things, I like the AAM but just see it being too pricey for what you get, and its kinda hard to see or read about what they exactly do, so if you guys can fill me in on some info if you dont mind.
Old Feb 12, 2007 | 01:50 PM
laswyguy's Avatar
laswyguy
Search techonosquare reflash buddy.
Old Feb 12, 2007 | 01:52 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I don't know exactly what AAM reflash does. But I'll tell you what technosquare reflash does.
Sets air/fuel ratio around 13.0 which makes best HP for N/A
I think it makes a slight timing adjustment
Basically what you would end up doing if you got a UTEC or something...
Old Feb 12, 2007 | 04:17 PM
Chebosto's Avatar
Chebosto
in addition: throttle body control, rev limit raise, speed limit removal, and some other 'stuff' to make driving fun.
if you're in So Cal, you should just roll over to Torrance and see Technosquare.
Old Feb 12, 2007 | 04:51 PM
IIQuickSilverII's Avatar
IIQuickSilverII
Technosquare +1000
Old Feb 12, 2007 | 09:36 PM
VtotheZ's Avatar
VtotheZ
Thanks
Technosquare, sounds like a great thing to look into, I was hoping there was something local to go check out, I need my car everyday so it would be hard to send my ECU out of state.
Setting the rev limiter higher would be a bad thing right, I mean they put a rev limiter there for a reason right? For long term I think it would do damage to the engine wouldnt it? (sorry to sound such like a newb)
So in turn, This would be a substantial mod to do, I always thought it was kinda lame to mod a car with boltons and not even get the full potential out of the car, and by doing this you can finally get every last HP/TQ out of what you spend.
One more question. Would it be pointless to do this to my car, I have NO mods.
Old Feb 12, 2007 | 11:02 PM
Chebosto's Avatar
Chebosto
Originally Posted by VtotheZ
Thanks
the rev limiter increase is to allow a 'safety buffer', you shift like you normally would but now with 500+ more RPMs to work with you dont have to worry about hitting the fuel cut off. also, if you have cams, raising the rpms sometimes helps out the power band ... stock rods on the 287hp VQ have been rumored to fail at sustained 7600+ rpms.. so setting it at 7100 or 7200 isnt as bad as you think.
as for no mods, you still get the benefits on advanced timing, the throttle body sensitivity change, and a more efficient running engine.. however you could feel more substantial gains if u add an intake, plenum spacer, and high flow cats then get a reflash.
if ur thinking about it, honestly i'd just recommend u go into torrance and speak to Tadashi about his tuning techniques and how he does it. that way you'll get a better understanding of what he can and can't do with a bone stock car.
Old Feb 12, 2007 | 11:15 PM
black06z's Avatar
black06z
Definitely check out Technosquare. I think it would be a waste of money to put it on a stock car. I would wait to at least put I/H/E and then have it done. I was reading somewhere, that this guy got the car back in the same day.
Old Feb 13, 2007 | 07:19 AM
Q45tech's Avatar
Q45tech
Before OBD2 ecu [prior to 1996] contained more safety reserve something like 10-15% to allow for sensor errors and aging. OBD2 requires back up redundant sensors so they can leave less and say they have more power..........why reflashes seldom create more than 5%.
A 1990-93 Q V8 went from 278 HP/290 lb/ft to 307 HP/320 lb/ft with just ecu reprogramming............those days are long gone when 30 units was available of anything for $500 thanks to tighter control and less safety reserve.
Old Feb 14, 2007 | 01:21 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
o yea
Old Feb 14, 2007 | 05:28 PM
first350's Avatar
first350
from what I've read, AAM and TS use basically the same thing to do the ECU flash...only difference will be location and the person doing it.
I just had my ECU flashed by AAM - since I live in Seattle, I'd have to send my ECU by mail...so I choose AAM b/c I've heard more good reports about their flashed and I've dealt with them in the past and had good experience.
-Peter
Workshop12
Mar 23, 2020 01:45 PM
PLAYDIRTY
Oct 12, 2015 07:45 AM
codek
Sep 27, 2015 03:21 PM
