Zeitronix sensors location??
Old Feb 17, 2007 | 06:52 AM
xav_350z's Avatar
xav_350z
Question Zeitronix sensors location??
the guy whos goin to install the wideband (zeitronix) needs some pics concerning the location of the 02 and EGT sensors.
so if u guys have some pics pls Help AND try to post them
10x!
Old Feb 21, 2007 | 06:13 AM
xav_350z's Avatar
xav_350z
anyone??
Old Feb 21, 2007 | 01:58 PM
booger's Avatar
booger
The O2 sensor goes on the header before the cat . The EGT sensor goes as close to one of the exhaust ports as possible
Old Feb 21, 2007 | 02:41 PM
THE TECH's Avatar
THE TECH
Although EGT is old school and more a waste than it is worth.
Old Feb 21, 2007 | 05:47 PM
peptidbond's Avatar
peptidbond
Actually, I would put the wideband sensor in your Crawford HFC. Specifically, in the driver's side cat. If you are under the car, look at where the cat meets the header. On the neck of the cat, there is a great mounting location for the sensor. Plus, there is plenty of space between the cat and the car body. Finally, this point allows you to mount the sensor on the top side so the sensor does not get any condensation on it (this is very important).
Why place the wideband sensor on the driver's side cat and not the header? Three reasons. The sensor will eventually burn out and you will have to replace it. When mounted on the cat, you can get a wrench on it really easily. Finally, should you need to remove the exhaust part to service the sensor, it is a lot easier to get the cat out. Plus, if you needed to remove the header, you would have to remove the cat anyhow.
Oh, and if you are thinking "but the sensor has to be before the cat", true. While I am suggesting you mount it to the cat, it will still be before the cat element.
Old Feb 22, 2007 | 01:01 PM
xav_350z's Avatar
xav_350z
10x a lot guys!
btw booger i got ur PM concerning the sensors location but the guy whos goin to install the wideband on my z needs pics...
i'll print this page and show it to him :P
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
