self-tuning at the drag strip?
Old Feb 23, 2007 | 04:24 PM
derek173's Avatar
derek173
Default self-tuning at the drag strip?
Getting my utec tuner installed soon. I see alot of threads with people tuning on the street. Wouldnt a drag strip be a better place?
This is for N/A tuning btw
Old Feb 23, 2007 | 09:13 PM
QuadCam's Avatar
QuadCam
not really,........you need to take some nice long 4th or 5th gear pulls starting at a low rpm to get some nice useful logs....
also, I do alot of street tuning that is just for part throttle acceleration.... WOT tuning is only a small part of tuning....actually, it is the easiest part.
part throttle driveabililty takes alot of time if you are really doing it right.
Old Feb 24, 2007 | 05:08 AM
Yes. That is what Test & Tune is for. Do some tweaking and run. Do a little more tweaking and run again.
Old Feb 24, 2007 | 05:16 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
+1, Find a dyno or a open empty road that has NO TRAFFIC whatsoever.
Old Feb 24, 2007 | 10:42 AM
derek173's Avatar
derek173
cool thanks for the explaining, Cant wait to start self tuning!
Old Feb 25, 2007 | 08:10 AM
dTor's Avatar
dTor
+2
Street tuning (i.e. not WOT) can be a time consuming process, but it's worth it.
Old Feb 25, 2007 | 10:57 PM
derek173's Avatar
derek173
Originally Posted by dTor
+2
well I want to get it perfect, thats why I want to self tune.
Old Feb 26, 2007 | 11:49 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
sure, you could do it on a drag strip if you don't mind looking like an idiot:
0. Start datalog
1. launch really slow
2. immediately shift to 4th gear
3. floor it
4. take it to to redline
5. roll through the finish line
If you don't care that other people will be asking "WTF is up with that guy" then go for it. Drag strip is definitely the safest place to do this.
Old Mar 1, 2007 | 08:02 PM
zluver's Avatar
zluver
I play with the UTEC at the drag strip. Just have everything ready to go when your in the staging lanes and then just hit the logger key when you hit the first stage light at the line. I use it to determine the differences between stock and my maps, not to make 4th gear passes, but I suspect it would work fine. The last time at the track I turned the UTEC on for the first time after make a few stock runs. Shifting at no more than 6750rpms I picked up an extra 1.5mph on my trap speeds over my previous bests ever.
Old Mar 2, 2007 | 07:10 AM
Shift_Z33's Avatar
Shift_Z33
Drag strip would be worse than the street. It would be a pain in the *** to keep waiting in line to go down the track. Street tuning part throttle can take hours to get it perfect.
Mw870
Oct 2, 2015 08:23 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
