Greddy E-01 displays reveiws??..
Old Apr 15, 2007 | 02:34 PM
IslandZavage's Avatar
IslandZavage
Default Greddy E-01 displays reveiws??..
What all is needed to make the E-o1 display A/F? can it display fuel pressure? i searched for reviews on here with no luck...can someone with knowledge on this comment pls......
Old Apr 15, 2007 | 03:31 PM
chris'smax's Avatar
chris'smax
you would need the auxilary input harness available at mohdparts.com. You must have a linear voltage wideband to tap into to get the reading. It gives you a step by step direction on how to set it up in the directions.
I am pretty sure you would be able to give a fuel pressure readout as long as you have a electronic fuel pressure sensor to tap into. Once again it would have to use a linear voltage readout.
Old Apr 15, 2007 | 04:02 PM
MardiGrasMax's Avatar
MardiGrasMax
I used a Profec E-1 for a while in my turbo Maxima and it was very helpfull. I had an Emanage Blue and was able to view all of the e-manage parameters, wide band O2, boost etc on the display which I mounted nead my stock gauges. being able to tune the e-manage and watch all the different data was ver ver very handy.
Workshop12
Mar 23, 2020 01:45 PM
sales@czp
Sep 23, 2019 03:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
