Datalog 02 Bank Question
Old Apr 4, 2007 | 10:52 AM
SpeedGeek's Avatar
SpeedGeek
Default Datalog 02 Bank Question
Hope someone can answer this.
When you datalog 02 voltage to see if your running rich or lean. Should you be reading from BANK 1 SENSOR 1 and BANK 2 SENSOR 2 ?
When I datalog from these two sensors BANK 2 voltage is much higher than BANK 1
Thanks in advance
Old Apr 4, 2007 | 12:48 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
actually B1 and B2 usually are a little off in terms of how rich/lean they are.
B1 is passenger side, B2 is driver's side
why don't you have widebands? your voltage doesn't go up to 5v?
Old Apr 4, 2007 | 01:14 PM
SpeedGeek's Avatar
SpeedGeek
Thanks Wired!
Good questions, it's a 2005 coupe. I should have them.
Old Apr 16, 2007 | 06:32 AM
h8bumps's Avatar
h8bumps
You should have both narrow- and wideband o2 sensors in each bank. The wideband (afr) sensor is in the exhaust manifold, and the narrow band o2 sensor is in the cat pipe. Looks like your graph was reading the narrow band sensors.
Old Apr 16, 2007 | 09:47 AM
QuadCam's Avatar
QuadCam
you need to look at B1,S1 and B2,S1 The "sensor 1" is the upstream O2 that controls fuel mixture. The sensor 2 is the one that gives info on whether the cats the are functioning properly or not.
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
