From SS Box to Utec
Old Apr 16, 2007 | 06:13 PM
Triji's Avatar
Triji
Default From SS Box to Utec
Ok... I am running the SS box at the moment and I believe when it was installed they had to cut / splice wires to get it installed... I am considering the UTEC now and wanted to know how much of a PITA it is to make the switch.
any help is appreciated, thanks.
Old Apr 16, 2007 | 07:51 PM
Barzten1's Avatar
Barzten1
DR Todd 350zDCalb did mine. Send him a pm. He's pretty good at that stuff
Old Apr 16, 2007 | 07:54 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
just wire it back to stock and its plug and play, except if you have a Vortech well, it tells the inline pump when to turn on.
that will be your only issue.
i would just ditch the FMU and put some big injectors in there.
Old Apr 16, 2007 | 08:10 PM
Triji's Avatar
Triji
Yeah, I am getting a walbro, 550's and a AAM return fuel kit.
Old Apr 16, 2007 | 08:11 PM
Triji's Avatar
Triji
Can I just buy a new wiring harness for my ECU instead of taking a chance on re-wiring back to stock? Is that even an option?
Old Apr 17, 2007 | 04:09 AM
Audible Mayhem
My350z
yes, i would recommend it for sure. wiring issues suck in these cars.
Old Apr 17, 2007 | 06:00 PM
tabbott's Avatar
tabbott
Hey Art this is Travis from AZ, anyway I am sure that your installer just piggybacked onto the existing lines so all you need to do is cut the lines from the SS box and make sure that there are no exposed wires on your ECU harness. The UTEC plugs into the stock harness and then the stock ECU plugs into the UTEC. Install time is like 30 minutes from start to finish. Good idea ditching the SS box and the inline pump. Let me know if you have any other questions.
Old Apr 17, 2007 | 09:45 PM
Triji's Avatar
Triji
Wassuppp Trav
Well with those lines cut wouldn't I have to splice it into the Utec since there would not be anything to connect it to... Isnt the SS box hardwired to the ECU in a sence?
Or is it tapped in mid stream?
Thanks Trav
Old Apr 17, 2007 | 11:52 PM
tabbott's Avatar
tabbott
Tapped midstream is a good way of describing it. All you need to do is take out the SS box by cutting the wires that were tapped into your ECU harness and slap the UTEC in and your good to go. I would recommend getting the Turbo XS Map sensor so you can tune your car more accuratly. I think it is referred to speed density mode when you base your tune off of pressure from the sensor as oppossed to the MAF voltage which is how your car is tuned now. Plus with the UTEC you can get the remote map selector switch and toggle between your 91 and 94 octane maps with the flick of a switch.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
