UTI Tables problem
Old May 9, 2007 | 09:26 AM
KaeruNoMe's Avatar
KaeruNoMe
Question UTI Tables problem
Hi all,
I have just downloaded the new UTI version 2.7.5 after the test with 2.7.4 from JeffSoftware.
I run the program on my 350Z with UTEC only (no wideband still), USB connection, and set 350Z mode, Inj size 380, Inj num 6.
UTI correctly connect and made logs, but I can't use the Tables, before and after clearing, UTI don't fill the table's cells.
The only way to see some activity is to use the wrx mode but the values are wrong.
When syncronized, after few time I see the error "Overflow".
I see these errors with both versions, and I made the tests with 2 notebooks (winXPpro and home).
Can you help me?
Thank you,
Nik
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
