Help on setting up Profec E-01 PLEASE!!!
Old May 18, 2007 | 01:46 AM
Concept350Z's Avatar
Concept350Z
Default Help on setting up Profec E-01 PLEASE!!!
Installed a Greddy TT Kit with Emanage Blue and E-01.
Some how the E-01 read the boost. Set the Boost at low 0.40 gain 10 and hi at 0.45 gain 10. However during during test run the boost goes up until 0.75.
Anybody know how to set up the e-01 to stop the boost maximum at 0.45?
NEED HELP URGENTLY. ALL HELP ARE GREATLY APPRECIATED!!
Also if you can please let me know how you guys setup your e-01 at and all the parameters.
Thank you
Old May 18, 2007 | 04:32 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
use the manual setting, .45 is going to give you around 10 to 11 psi.
the auto setting doesnt work very well with the greddy tt setup.
double check all the vacuum lines, make sure you have the pressure side of the EBCS going into the right side and the left side going to the top port of the WGS.
good luck!!
