UTECH or AAM ECU Reflash?
Old Jul 12, 2007 | 02:17 PM
PunKidd's Avatar
PunKidd
Originally Posted by josh846
Skater, they are having other pro-tuners set up to use it so you can take your car there and get it tuned in person. I would imagine that anyone with FI needs to get it done in person, not just an E-mail flash. If you are not FI then I am sure UPREV's E-mail tunes will do fine. It is always better though to be able to actually have the car on the dyno and tune it in person.
Correct. We don't even offer Osiris for FI application (even though we've tuned many more FI VQs than NA VQs). It's just too risky. FI tuning has to be done in person on a dyno.
Jared.
Old Jul 12, 2007 | 03:18 PM
skaterbasist's Avatar
skaterbasist
Originally Posted by PunKidd
We'll still offer eTuning for AFR, but it should lighten my load quite a bit if people can go to their local tuner for a full blown dyno tune (which is better than eTuning where we only mess w/ the AFR on a generic base ignition map).
Josh, thanks for the Clarification.
Jared, you've helped a ton. I have another question that just arose; sorry for all the questions, but I like the feel completely confident about any product I buy.
Regarding your last statement; I was always under the impression that the "fine tuning via email" with cipher logs (or dyno graphs) being provided was sufficient enough to be allow UpRev to tune the map just as if they were doing it in person; your last statement seems to contradict this belief I had.
Can you please elaborate? What's the advantage of a local tuner vs UpRev's fine eTuning with cipher logs (or dyno graphs with AFR) being provided?
Thank you for being patient with me. I completely understand your need of local tuners; It's just too much for any single person to handle on such a high demand. But I would like to keep these tunes via UpRev
PS. I'm NA only; so FI situations don't apply to me.
Old Jul 12, 2007 | 03:38 PM
PunKidd's Avatar
PunKidd
The big one is ignition. We only tune the AFR via eTuning. To tune ignition we need dyno feedback. This can be done via emailing dyno charts as well as logs, but we typically make between 10 and 25 adjustments to ignition @ WOT during a dyno session, so that would make for A LOT of trips to the dyno. We also do load testing to hit multiple load/RPM points when we have the vehicle on the dyno. This kind of tuning can ONLY be done in real time on the dyno.
We can get AFR dialed in via eTune relatively quick, but ignition requires a dyno and ignition is where the big power gains come from. The tuned ignition tables that are provided in our base maps are more aggressive than stock, but a custom dyno tune will always yield better results.
Jared.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Stevo Z
Oct 3, 2015 09:14 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
