Utec install cost?
Old Sep 4, 2007 | 02:49 PM
Triji's Avatar
Triji
Default Utec install cost?
How much should I expect to pay for a Utec install in a "G"?
I also have 660 Inj's on the way, can the stock fuel system handle these or should I go for a CJM return kit and walbro?
Old Sep 4, 2007 | 02:54 PM
Blackbird CPV35's Avatar
Blackbird CPV35
its a pretty straight forward process as far as installing it. You can do it yourself easily, the harness is completely plug and play. Tuning it on the other hand is another story.
Old Sep 4, 2007 | 02:58 PM
THE TECH's Avatar
THE TECH
You'll need a flash if you want to run the 660s on the stock ECU.
Triji's Avatar
Triji
Yeah, I definately will get it tuned somewhere... I am not going to mess with that myself quite yet.
I heard install on a "G" is a PITA to get it to fit... I guess I can take the under dash apart and dremel out a place for it. I am skiddish on installing it myself then driving an hour away for tuning...
Also have to take the SS box out as well.
Old Sep 4, 2007 | 02:59 PM
Triji's Avatar
Triji
I thought the Utec can scale the 660's? What kind of flash do you reccomend?
Old Sep 4, 2007 | 03:01 PM
THE TECH's Avatar
THE TECH
Sorry, I thought you meant to have the stock ECU run them. For UTEC, you'll have no problem.
Old Sep 4, 2007 | 03:03 PM
Triji's Avatar
Triji
OK.... whew... you just scared the fashizzle outta me for a sec.
What about the stock fuel system w/ 660's? Or should I go CJM and Walbro?
Old Sep 4, 2007 | 03:04 PM
G35asian's Avatar
G35asian
Art,
The install is definitely a piece of cake. If you want some help I can lend a hand if needed . As for placing the UTEC in a G so it is out of sight, good luck making room . I tried to move stuff around for hours and could not get it fully hidden. A dremel will work if you want to start hacking the wire harnesses that are in the way lol.
As for limping it to the tuner, TXS has some base maps you can load of off their website. Just don't hit boost on the way down there and you will be fine. Thats what I will be doing next week. Call me if you have any more questions.
Old Sep 4, 2007 | 03:08 PM
G35asian's Avatar
G35asian
At least get a walbro. They are only around $90 shipped. I am running 650's and a walbro which is the fuel setup of choice by Performance Factory in FL for their vortech'd motors. This being owners that are not ready to spend the money on a return system.
Old Sep 4, 2007 | 03:09 PM
Triji's Avatar
Triji
Cool, thanks Julian.
I'll let ya know, are you going to UMS for tuning?
Let me know how that goes for ya.
Old Sep 4, 2007 | 03:11 PM
G35asian's Avatar
G35asian
Yeah, i'm going to UMS. I'm pretty confident that Tony will do a good job since he has tuned many utecs before. He also tuned TTrank's sedan which is pushing over 400rwhp on a stock block greddy tt setup
Old Sep 4, 2007 | 03:14 PM
Nexx's Avatar
Nexx
for a vortech... 550 and 650 would be plenty. walbro would be a good idea. the return is a waste for vortech setups.
Old Sep 4, 2007 | 04:18 PM
THE TECH's Avatar
THE TECH
What is your reasoning for that?
Old Sep 4, 2007 | 04:28 PM
carfi179's Avatar
carfi179
TecH, Are you running with UTEC on your SC? If so....do you carry it and PM how much.
-Mike
Thanks!
Old Sep 4, 2007 | 04:43 PM
THE TECH's Avatar
THE TECH
-Mike
Thanks!
Nope, just using the proven SS box. No real need for the UTEC.
No, I don't carry the UTEC. I can order though.
Old Sep 4, 2007 | 05:12 PM
Triji's Avatar
Triji
I have been running the SS box with no problems as of yet. Although recently I have been puzzeld as to why I am only boodting 5psi with the 3.12 pulley where as I used to boost at 9psi with it. I am also running rich 10.5 - 11's under boost...
I tightend the belt but that didnt do it. I am thinking about taking her in for a leak (smoke) test to see if the SSV has developed a leak but I thought that should in theory create a lean condition instead of the rich condition I am seeing.
Can the SS box "unlearn" a tune if you do a 12 hour disconnect on the battery?
Old Sep 4, 2007 | 05:26 PM
THE TECH's Avatar
THE TECH
Nope.
I wouldn't change to the UTEC unless you think there is a "need" to. No reason to spend more money on something that won't do much more for you than what you have now.
The boost issue probably has nothing to do with the SS box.
Old Sep 4, 2007 | 06:51 PM
Triji's Avatar
Triji
hmm, I'll try re-uploading my latest tune from my laptop onto the SS box and see if that does anything for the AFR's I guess.
Old Sep 4, 2007 | 09:03 PM
Nexx's Avatar
Nexx
there are vortech owners running stock injectors with the 3.12 pulley pushing around 8psi with no fuel issues what so ever. i have yet to see anyone running a vortech blow a motor due to fuel problems. i personally run a vortech with no return, as most people arent. performance factory would tell you the same. i win!
Old Sep 4, 2007 | 09:57 PM
Triji's Avatar
Triji
I have been running stock injectors with the 3.12 for over a year... I am going to the 2.87 and just do not think the stock will be sufficient with that pulley however.
