UTEC: can it datalog coolant temperature?
Old Sep 18, 2007 | 03:42 PM
Biochem7's Avatar
Biochem7
Regular
Default UTEC: can it datalog coolant temperature?
I know the dashboard displays the coolant temps, but can we actually log the temperatures?
Old Sep 18, 2007 | 05:26 PM
QuadCam's Avatar
QuadCam
you can if you use the UTI software. It logs my coolant temps and my air inlet temps, along with all the other uTEC stuff.
Old Sep 19, 2007 | 03:43 AM
KPierson's Avatar
KPierson
I've got the UTI software and I didn't know it logged those other params.
Old Sep 19, 2007 | 05:53 AM
athenG's Avatar
athenG
I think it does but you have to be using the Dashboard out, at least logger1 doesn't contain them even if it is selected.
Old Sep 19, 2007 | 07:27 AM
raditz's Avatar
raditz
I thought that the UTI in the 350Z only worked in logger1 mode
Old Sep 19, 2007 | 07:55 AM
athenG's Avatar
athenG
I was using MPS and I just switched to UTI, I have been working with Jeff to make his software to work with my Windows 98. I get an error when I switched to Dashboard but the error was because of my low memory (64MB), I will try this with my new laptop and see if it work. Did you try the update?
Old Sep 19, 2007 | 11:49 PM
mthreat's Avatar
mthreat
I used cipher from uprev to log my coolant temps, www.uprev.com
Old Sep 20, 2007 | 07:37 AM
QuadCam's Avatar
QuadCam
th UTI defiantely works. It shows the coolant and air temps on the dashboard, and I have also set it up to add them to the logs the UTI creates. Go through all the setup paramters.
Old Sep 20, 2007 | 08:00 AM
Biochem7's Avatar
Biochem7
Regular
Jeff from jeffsoftware.com confirmed that the UTI program has this feature.
Thanks for the help guys!
Old Sep 20, 2007 | 08:10 AM
raditz's Avatar
raditz
How you did to have the temps on the dashboard? mine it's showing 0 all the time
Old Sep 20, 2007 | 08:58 AM
QuadCam's Avatar
QuadCam
it is one of the settings on the drop down menu on the top left of the window..IIRC. I don't recall ,and I don't have time to leave the office and check it right now.....BTW, you have to be running the latest version of the UTI software. (it came out a couple months back.)
Old Sep 20, 2007 | 09:51 PM
raditz's Avatar
raditz
Well, on the manual saids that the 350Z version only works in logger1 mode, but I have tried it in dashboard mode and it works, showing the temperatures!!!
It's there any way to read the ECU ignition timing and the UTEC timing? Also, in the tables, is shown the same for "timing" and "ECU timing".
Old Oct 3, 2007 | 09:59 AM
gothchick's Avatar
gothchick
From the main menu, there are 1 thru 6 logging options with UTEC. 1 through 6 do work on my UTEC. I can't remember which logger option logs coolent temps off the top of my head though. Just open each one until you find the one that logs coolent temps...
Attached Thumbnails UTEC: can it datalog coolant temperature?-main-menu.jpg
Old Oct 3, 2007 | 10:29 AM
QuadCam's Avatar
QuadCam
I think it is logger "2". If you want a "full" log including air and coolant temps, you have to use the UTI software though. Logger "2" won't give you a complete log, like Logger "1" though. If you just want to see psi, load site, coolant, air temps, and rpm, then Logger "2" works just fine.
Old Oct 3, 2007 | 11:18 AM
athenG's Avatar
athenG
I have been using UTI and every time I select Dashboard it doesn't do anything. I mean everything is blank, the only way I see data is when selecting Logger1. That could be the reason there is nothing on my logs even if I select AIT as an option.
Old Oct 3, 2007 | 11:44 AM
mikead_99's Avatar
mikead_99
Are you using the latest version? I use V2.7.5 and get complete logs, including the AIT and Coolant temps with Dashboard as the source.
Old Oct 3, 2007 | 12:28 PM
athenG's Avatar
athenG
I have the newest Ver. and Dashboard seem not to work for me even selecting Maf or SpeedDensity mode, I get blank and only get data when using Logger1. The only difference is that I'm using USB for Utec, I'll try using Serial connection if that help.
Old Oct 3, 2007 | 01:29 PM
gothchick's Avatar
gothchick
Yeah.... Utec is kinda quirky with usb.... Serial pretty much works 100% of the time.
Old Oct 3, 2007 | 05:22 PM
mikead_99's Avatar
mikead_99
I agree with gothchick on this, I think you are probably on the right track athenG. I'd heard enough about user problems with the usb interface that I never bothered trying it even though it rubs me wrong to not be able to use something a little less archaic. The serial connection has been pretty solid for me and it's not like you gain anything from the transfer speeds usb could get you, you just get the convenience of not dealing with a nearly obsolete interface.
Old Oct 3, 2007 | 06:54 PM
athenG's Avatar
athenG
The problem is the the only Laptop I have that has a Serial connection can only run on Windows 98 I was able to make UTI work with it but when I try using Dashboard mode on 98, I get a memory error (really old laptop). Now I'm using another laptop that has XP but no Serial
