Tuning without engine management
Old Sep 21, 2007 | 09:21 PM
iceagetlc's Avatar
iceagetlc
Default Tuning without engine management
Have you guys ever heard of a type of dyno tuning where the shop does a pull on the dyno, adjusts the AFR and timing slightly then does another pull and adjusts it a little more finely and finally a third time more finely? Like without a piggy back or new ECU. My brother says that thats just a more basic dyno tune that can be done for less power gains but still some.
Old Sep 21, 2007 | 11:00 PM
i8acobra's Avatar
i8acobra
It's called reflashing. There are a few shops who can flash the Z on the dyno, but not many. Problem is that there are only a few companies selling tuning software and they charge way too much to make it profitable for smaller shops to invest in the software. I can tune GM cars for $250 and make a decent profit. For me to buy software to tune the Z, I'd have to charge double that to make any money.
Old Sep 21, 2007 | 11:08 PM
iceagetlc's Avatar
iceagetlc
well thats not exactly what im talkin about, i mean like just tune the AFR at certain RPS with the AFM, then fine tune the timing while dynoing?
Old Sep 21, 2007 | 11:51 PM
i8acobra's Avatar
i8acobra
I don't understand what you're asking. If you want to know if the dyno itself can tune a car, no. The dyno reads your a:f ratio using an O2 sensor, it doesn't communicate with your ECU. The only way to change your tune (either a:f ratio or timing) is by connecting a laptop with tuning software to your ECU through the OBD port under your dash. For a shop to buy the software and cable to tune Z's costs several thousand dollars.
Old Sep 22, 2007 | 07:56 AM
punish_her's Avatar
punish_her
Um to make it more clear. You can tune with out the an EMS. You need OSIRIS. You can reflash as many times as you want and its not that expensive.
Old Sep 22, 2007 | 08:50 AM
MR_X's Avatar
MR_X
If you are talking about tuning without a ECU or any electronics, then is called a engine with carburetors. Or unless you are talking about like OBD I cars where you can play with adjustable fuel pressure regulators.
Old Sep 22, 2007 | 10:15 AM
i8acobra's Avatar
i8acobra
No, you cannot tune on the dyno with OSIRIS. You must send a log file to UpRev and wait for them to email you a revised map. No dyno shop is going to let your car sit on the dyno that long without charging you their customary hourly rate.
This is the software I was referring to in my previous post. The cost of the tuner version is too high to make it worth any local shop buying it. For me to just break even, I'd have to charge over $500 for a tune. To make it really worth getting, I'd have to charge about $750 for a tune.
Old Sep 22, 2007 | 10:53 AM
dovla's Avatar
dovla
On how many customers and at what Osiris tuner version cost is your calculation based? Thanks
I think that on short run you are right but on the long run tuning price could/should be lower.
Old Sep 22, 2007 | 11:15 AM
i8acobra's Avatar
i8acobra
The Osiris Pro Tuner Suite. The problem for me is the minimum license initial buy-in. I don't think there are that many Z's in Vegas in need of a tune. I can think of about 6 off the top of my head. I have no interest in doing mail-in tunes. Paying my dyno guy $100, I'd have to charge $475 for the first initial tunes just to break even. I'd be in the hole until I did those first initial tunes and even after that, I'd only be making $75.
Old Sep 22, 2007 | 07:18 PM
punish_her's Avatar
punish_her
Yeah I caught that late last night and was too lazy to post it up. Yeah its not too echenomical for the tuning shop but for the every day Joe Blow with N/A bolt ons it should be fine. The cost of the Osiris setup is WAY cheaper than an EMS and DYNO tune. So for some one who doesnt have enough mods to justify it to them selves to get the EMS and dyno tune should look at the OSIRIS.
Old Sep 22, 2007 | 10:19 PM
i8acobra's Avatar
i8acobra
I agree with you 100%. It's just that the OP wanted to know if there was a way to tune on the dyno without an aftermarket ECU. The short answer is, only if your tuner is one of the few who has the 350Z tuner software.
Old Sep 22, 2007 | 10:55 PM
punish_her's Avatar
punish_her
You can Dyno tune with Osiris but it takes alot longer. You do a few pulls while logging and send that in. You get the reflash and load it. Do a few dyno pulls while logging, etc etc. You will eventualy get there but it will take about 2 or 3 sessions of pulls over a longer period of time. So if your patient, then its all good.
Old Sep 23, 2007 | 05:07 PM
i8acobra's Avatar
i8acobra
I guess you're technically correct, but I believe he was asking if it could be done while the car is on the dyno, which it can't.
Old Sep 23, 2007 | 06:16 PM
__jb's Avatar
__jb
Z + Rear Seat
I have Osiris and am hoping to find a shop in Florida that will license the Pro Tuner Version. I've been wondering why no local dyno shops have jumped onto the bandwagon, maybe you've got the answer.
It seems like my only alternative for a real-time dyno tune is to buy a UTEC and have it tuned. That will be more expensive that your $750, but I'm not too close to Vegas anyway. My other choice is to wait for the Home Tuner version of Osiris and rent some dyno time on my own, or more likely, hope the map adjustments are similar enough to the UTEC Tuner Kit so that my local tuner can figure it out.
I guess the number of people interested in the real-time tunes without a ECU piggyback is limited to NA people that are serious enough to value it.
Old Sep 23, 2007 | 11:26 PM
SergEK's Avatar
SergEK
I think as more people realize the power of tuning with a good tuner they will spend the money to make more power
Considering Shawn Church is offering an OSIRIS tune for 600 and an hourly rate after that of (I think) $75/hour for future dyno time thats an awesome deal
CHeap to get started 600 --- then you get a new mod and its 75 for a solid hour of tuning to adjust the maps to your new mod --- by someone who knows what they are doing
There wont be too many guys willing to shell out the dough for licence fees but the big shops should be all for it as its easily the most convenient way for entry level tuning
OSIRIS is perfect for NA guys who just need a full tune but arent looking to make 800+whp ya know....at that point a Vpro will be justifiable
Old Sep 24, 2007 | 07:57 PM
Peak350's Avatar
Peak350
Weird question, but were you by chance on Bimmerforums for a while a couple years back?
Old Sep 25, 2007 | 07:56 AM
__jb's Avatar
__jb
Z + Rear Seat
I think that's a tremendous deal!
I wish a Florida Tuner would provide that option. Jeremy - You listening?
Agreed... I think it will be a popular product once it catches on.
I wish it had a way to handle knock, though...
Old Sep 25, 2007 | 04:48 PM
westpak's Avatar
westpak
SFZCC
Yes you can just turn the top screw on the carburetor and get a timing light to help adjust the timing
Old Sep 29, 2007 | 10:07 AM
oldskoolZ's Avatar
oldskoolZ
Im the brother.... where i made a mistake was 350'z use distributeless ignition systems, BUT wat im saying is put a car on a dyno, rpm lock it and manualy adjust the AFR at the MAF, as far as timing idk how to time 350's DIS, idk where the pick up is or if that is how you would even adjust it. On cars with standard distibuter ignition systems, you can adjust the timing and timing curve very easily. Sry about the long drawn out dissucsion on this.
Old Sep 29, 2007 | 10:20 AM
westpak's Avatar
westpak
SFZCC
You can only adjust the timing via the ECU
With a consult or Cipher you can increase or decrease it by 4-5 degrees but that is across the board, to make changes in a map you either need the new Osiris to flash the ECU or a piggyback computer which can also do fuel so no need for an AFC to just do fuel
