Tuning without engine management
Old Sep 29, 2007 | 10:37 AM
i8acobra's Avatar
i8acobra
Originally Posted by oldskoolZ
Im the brother.... where i made a mistake was 350'z use distributeless ignition systems, BUT wat im saying is put a car on a dyno, rpm lock it and manualy adjust the AFR at the MAF, as far as timing idk how to time 350's DIS, idk where the pick up is or if that is how you would even adjust it. On cars with standard distibuter ignition systems, you can adjust the timing and timing curve very easily. Sry about the long drawn out dissucsion on this.
There is not adjustment on the MAF. All tuning must be done through the ECU, both fuel and timing.
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
