Na/ dyno dynamics/ utec tuned
Old Sep 30, 2007 | 08:52 AM
rx7/350z's Avatar
rx7/350z
Default Na/ dyno dynamics/ utec tuned
I was told the numbers would be alot higher on a dyno jet. My tuner said he could of put in a high correction number but it's pointless. The numbers were alot better than what i thought i would get. car pulls aswome now. a/f was right around 13.2 till about 4000. after 4 it was tuned to about 12.7-8
install in driveway the night before
on the dyno (not strapped down yet)
and the results
So what do you think??
Old Sep 30, 2007 | 09:01 AM
Jay'Z's Avatar
Jay'Z
I guess thats good for NA.. Why the Deeznuts plates?? You must be a comedian..
BTW what rims are those?
Old Sep 30, 2007 | 09:06 AM
rx7/350z's Avatar
rx7/350z
privat netz perfect fitment. 20x8.5 +20 20x10 +20. contact adam@z1 for a great deal. that's funny i just read your sig. i had the 20" axis mods on my car before these. i hated the offsets on those
Old Sep 30, 2007 | 09:10 AM
Jay'Z's Avatar
Jay'Z
Do they rub your fender liner like hell??
Old Sep 30, 2007 | 10:18 AM
rx7/350z's Avatar
rx7/350z
no. not at all. the axis mods do because of the offset.
Old Sep 30, 2007 | 01:46 PM
I assume those are not before and after tune numbers. So we don't know what the UTEC and tune gain was. Or if there was any gain.
Old Sep 30, 2007 | 02:04 PM
quidproquo's Avatar
quidproquo
Need a Tune!!!
You probably would have pulled an even 290 HP on a DynoJet... Good numbers!!
How much was the Utec and tune installed?
Old Sep 30, 2007 | 02:08 PM
Alberto's Avatar
Alberto
Cranky FI Owner
What were the before/after numbers?
Old Sep 30, 2007 | 02:14 PM
DanielW's Avatar
DanielW
if this is DD uncorrected that might be like 280 on a dynojet i would think
Old Sep 30, 2007 | 03:23 PM
rx7/350z's Avatar
rx7/350z
yes those numbers are uncorrected dyno dynamics numbers. the red line is the base pre-installed utec map and the blue is the new tune.
Old Sep 30, 2007 | 03:26 PM
rx7/350z's Avatar
rx7/350z
as it shows on the chart the red was the first run of the day and the blue was the 13th. the preinstalled map mad my car run a little too rich but it felt better than it did on the factory map. we leaned it out closer to 12.8-13.2. i think the first run was around 241 with the a/f around 11.9 to 12.4. The tune made really big gains past the peak. my questions are : is it safe to rev that high and what should i be shifting at when i'm racing?
Old Sep 30, 2007 | 04:32 PM
SergEK's Avatar
SergEK
Shift at redline and stay in your powerband....shifting lower will just be slower...your call
Old Sep 30, 2007 | 07:28 PM
Thanks. This looks like a 15 horsepower peak gain with the UTEC and tune. Good results.
Old Sep 30, 2007 | 07:34 PM
You will have to experiment. At about 6,600 RPM you with reach a dead point where the car is no longer accelerating. Try different shift points.
Old Oct 1, 2007 | 09:37 AM
rcdash's Avatar
rcdash
That's incorrect. As SergEK mentioned above, shift at redline.
Torque does fall off at the crank near redline, but you are still accelerating much harder in a lower gear than when you upshift to the next gear.
Old Oct 1, 2007 | 10:12 AM
DanielW's Avatar
DanielW
^^^ wut he said
Old Oct 1, 2007 | 10:24 AM
I don’t know where redline is. Was it altered with the UTEC?
Old Oct 1, 2007 | 03:17 PM
rx7/350z's Avatar
rx7/350z
yes the utec brought the recline to 7200 like it shows in the dyno. I kinds got the just of shifting near redline. It seems to stay in the powerband best when I shift at like 6700.
Old Oct 1, 2007 | 03:24 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Off topic but that custom plate is comedy but I doubt they would allow that in Cali............LOL
Old Oct 1, 2007 | 07:27 PM
SergEK's Avatar
SergEK
Looking at the graph, shifting at redline with his powerband keeps him in a much higher avg horsepower area....more avg hp being made, quicker ET
Thats my opinion...if torque dropped off big time I would move it lower but if you look at the hp curve it trails off slowly to redline.....
For drag, I take a snap shot of the last 2K rpm window...from 5200 to 7200 is better than 4200 to 6200 powerwise on that graph...I guess you can compare acutal numbers just to be sure
