amateur tuning question
Old Oct 3, 2007 | 04:10 PM
haidz's Avatar
haidz
Default amateur tuning question
i have searched all around but coudlent find the answer i needed. I have an 06 manual and was wondering what good would getting a utec or such help with gains. The only thing i have on is a plenum and soon a popcharger and maybe exhaust. WIth these mods will i be getting noticible gains if i get my car tuned? and waht system do you recommed? thank you all ahead of time
Old Oct 3, 2007 | 05:18 PM
eltness350's Avatar
eltness350
The Untouchable
utec all the way...but before u get burned ...do a little searchin around the forum and ask some of the vendors...they are full of info and ready to take our money!! lol jk...
Old Oct 3, 2007 | 05:38 PM
h8bumps's Avatar
h8bumps
I've had both UTEC and Osiris/Cipher, and my 2 cents:
UTEC is easy to tune AFR, but timing it is difficult to get optimum settings because of temperature changes. Your stock ECU changes ignition timing depending on temperature (and maybe other variables), so a timing curve that pulls hard at 70 degrees may knock like a **** at 100 degrees.
Osiris/Cipher: Cipher itself can bump your stock timing 2 degrees across the board. This is a good starting point for advanced timing. Osiris can tune your AFR.
Another benefit of Osiris/Cipher is that you can log your AFR from your factory O2 sensors. With UTEC, you have two options: 1) get UTEC tuner, and install an extra O2 sensor in your exhaust to log AFR, or 2) log AFR using factory O2 sensors and Cipher. If you're going to buy Cipher to log AFR, you might as well buy Osiris/Cipher package.
And yes, noticeable gains with timing and AFR adjustment.
Old Oct 3, 2007 | 05:51 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
if you search around for threads started by me, you will notice about 25hp gains from plenum, high flow cats, popcharger and tuning on stock exhaust ... probably a little more with a good exhaust system
that said, you haven't been doing your homework. search the forums, find dynos, and learn for yourself
Old Oct 3, 2007 | 08:51 PM
RebelinRI's Avatar
RebelinRI
Oh Oh........... now you done it!!! You went gone done ticked off the teacher now!! I better not get extra homework because of you.
Old Oct 3, 2007 | 09:29 PM
SergEK's Avatar
SergEK
OSIRIS FTW!
Getting mine soon, no later than Xmas! lol
Old Oct 4, 2007 | 08:38 AM
gothchick's Avatar
gothchick
AHHHHHHHHHHHHHH!!!!! Homework for everyone!!!!
Old Oct 5, 2007 | 06:00 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
Looks like I'll be taking a trip to Austin to see those UpRev boys..
after mods are complete : )
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
