Turbo XS BCS install: boost map needed
Old Nov 1, 2007 | 10:30 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Here is a 4th gear pull with Test Pipes, Nismo midpipe, Nismo y-pipe, and the STS starter map on the 4.5lb wastegate springs. AFR says rich for I dunno what reason. My wideband read 10.0 to 10.3 to the whole time. Hopefully I will have the BCS hooked up tonight.
Code:
RPM       PSI   Ld   Ign     Knock
2534 038  -4.4  00  ECU. rich 00000
2577 102  -0.5  10 +21.0 rich 00000
2570 104  +0.1  20 +21.0 rich 00000
2546 104  +0.1  20 +21.0 rich 00000
2566 104  +0.3  20 +21.0 rich 00000
2568 104  +0.5  20 +20.9 rich 00000
2579 104  +0.6  20 +20.8 rich 00000
2592 104  +0.8  20 +20.6 rich 00000
2596 104  +1.0  30 +20.5 rich 00000
2608 104  +1.2  30 +20.3 rich 00000
2632 104  +1.4  30 +20.1 rich 00000
2670 104  +1.5  30 +20.0 rich 00000
2668 104  +1.7  30 +19.9 rich 00000
2658 103  +1.9  30 +19.7 rich 00000
2662 104  +2.1  30 +19.5 rich 00000
2705 104  +2.2  40 +19.5 rich 00000
2692 104  +2.4  40 +19.3 rich 00000
2741 103  +2.5  40 +19.2 rich 00000
2757 104  +2.6  40 +19.1 rich 00000
2725 104  +2.9  40 +18.9 rich 00000
2757 104  +3.0  40 +18.9 rich 00000
2796 104  +3.1  40 +18.6 rich 00000
2801 104  +3.2  40 +18.5 rich 00000
2824 103  +3.4  50 +18.3 rich 00000
2836 103  +3.5  50 +18.1 rich 00000
2805 103  +3.8  50 +17.9 rich 00000
2834 103  +3.9  50 +17.5 rich 00000
2846 103  +4.0  50 +17.3 rich 00000
2901 103  +4.2  50 +17.0 rich 00000
2881 103  +4.3  50 +16.7 rich 00000
2918 103  +4.4  50 +16.5 rich 00000
2916 103  +4.7  60 +16.2 rich 00000
2931 103  +4.8  60 +16.1 rich 00000
2978 103  +4.9  60 +15.7 rich 00000
3003 103  +5.1  60 +15.4 rich 00000
2976 103  +5.2  60 +15.3 rich 00000
2984 103  +5.4  60 +14.8 rich 00000
3063 103  +5.6  60 +14.8 rich 00000
3069 103  +5.6  60 +14.7 rich 00000
3060 103  +5.6  60 +14.6 rich 00000
3072 103  +5.6  60 +14.7 rich 00000
3118 103  +5.7  60 +14.6 rich 00000
3100 103  +5.7  60 +14.6 rich 00000
3156 103  +5.6  60 +14.7 rich 00000
3171 104  +5.6  60 +14.7 rich 00000
3159 104  +5.6  60 +14.7 rich 00000
3180 104  +5.6  60 +14.7 rich 00000
3192 104  +5.7  60 +14.6 rich 00000
3211 104  +5.6  60 +14.7 rich 00000
3284 104  +5.6  60 +14.7 rich 00000
3290 104  +5.6  60 +14.6 rich 00000
3271 103  +5.6  60 +14.6 rich 00000
3323 104  +5.7  60 +14.6 rich 00000
3310 104  +5.7  60 +14.6 rich 00000
3360 103  +5.7  60 +14.6 rich 00000
3397 104  +5.7  60 +14.6 rich 00000
3370 104  +5.7  60 +14.6 rich 00000
3380 104  +5.7  60 +14.6 rich 00000
3401 104  +5.7  60 +14.6 rich 00000
3415 104  +5.7  60 +14.6 rich 00000
3465 104  +5.7  70 +14.6 rich 00000
3490 104  +5.7  60 +14.6 rich 00000
3472 104  +5.7  70 +14.6 rich 00000
3512 104  +5.7  60 +14.6 rich 00000
3505 104  +5.7  70 +14.6 rich 00000
3553 103  +5.7  70 +14.6 rich 00000
3549 103  +5.7  70 +14.6 rich 00000
3561 103  +5.7  70 +14.6 rich 00000
3576 103  +5.7  70 +14.5 rich 00000
3603 103  +5.7  70 +14.6 rich 00000
3627 103  +5.8  70 +14.5 rich 00000
3683 103  +5.8  70 +14.5 rich 00000
3679 102  +5.8  70 +14.5 rich 00000
3711 103  +5.8  70 +14.5 rich 00000
3699 103  +5.8  70 +14.5 rich 00000
3724 103  +5.8  70 +14.5 rich 00000
3779 103  +5.9  70 +14.4 rich 00000
3792 103  +5.9  70 +14.4 rich 00000
3805 103  +5.9  70 +14.4 rich 00000
3844 103  +5.9  70 +14.4 rich 00000
3844 102  +5.8  70 +14.2 rich 00000
3853 103  +5.9  70 +14.3 rich 00000
3880 103  +5.9  70 +14.1 rich 00000
3880 102  +5.9  70 +14.0 rich 00000
3926 077  +5.9  70 +13.9 rich 00000
3912 014  +3.9  50 +15.6 rich 00000
Old Nov 1, 2007 | 10:58 AM
athenG's Avatar
athenG
Use Logger 1 when doing some logging since it is more complete, also 5th gear pull is 1:1 but there is not enough space to log until redline.
Try to download MPS (trial version) since this will help you log your A/F with Utec. I say just shell out some $$ and get the UTI Software coz it is much better and give you more extras.
Old Nov 1, 2007 | 11:21 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
I will try 5th gear next time. I would like to get the AFR logged but I may need another expensive Radio shack serial to usb cable thing...may be worth it in the long run.
Old Nov 1, 2007 | 12:45 PM
athenG's Avatar
athenG
If you already have one Serial Connection then try using straight USB with Utec and use the Serial for your Wideband.
Old Nov 1, 2007 | 01:00 PM
athenG's Avatar
athenG
Why are you hitting almost 6psi of you only have a 4.5 spring without the BCS?
Old Nov 1, 2007 | 01:21 PM
QuadCam's Avatar
QuadCam
because he is using a boost controller to raise the boost.
Old Nov 1, 2007 | 01:38 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
not right now. I have not hooked up the boost controller. That log is just on the wastegate springs. Not really sure why I am spiking that high...
Old Nov 1, 2007 | 02:41 PM
QuadCam's Avatar
QuadCam
I see....said the blind man.
Old Nov 1, 2007 | 02:49 PM
Drewer's Avatar
Drewer
. . .as he picked up his hammer and saw.
Old Nov 2, 2007 | 10:03 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
My BCS is installed and my lines are hooked up...time to load up a map and see if it works
Old Nov 2, 2007 | 10:18 AM
athenG's Avatar
athenG
good luck and pay close attention on your gauge!!! Test it at 4th/5th gear so your RPM won't climb that fast.
Oh, don't forget to set your boost cutoff.
Old Nov 17, 2007 | 12:29 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
I finally got a chance to play around with the BCS.
I only did a few 5th gear pulls with the 90% and 100% colums set to 8(closed loop). That resulted in peak boost of 6.4.
I will keep trying to get something out it tomorrow when it isn't raining or dark. I need to jump up a little bit but I really don't want to hit the fuel cut out.
Old Nov 19, 2007 | 04:50 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
I think I have a plenum leak...and I finally found the source of an annoying rattler... The test pipe on the passenger side is hitting the charge air pipe when the engine is at certain RPMs
Hopefully I can sort this out before going to SGP in the morning.
Old Nov 19, 2007 | 06:38 AM
athenG's Avatar
athenG
I'm curious how you make out. Jeremy said TegraRacer134 is not hitting full boost at 2nd and 3rd (Full Boost is 10psi has some Testpipes). I did some hard pull Sat. night from 1st-2nd and I'm surprised to hit 6.8psi at 1st and 8.6 at 2nd (My full boost is 8psi). Not sure if it's the Weather or my IC getting better Air Flow. I think not hitting Full boost at first is really a good thing coz I'm already having traction problem as it is and that is just lunching my car at 2000rpm.
Old Nov 20, 2007 | 06:04 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
SGP Tune 370hp at 8.2 PSI
My bcs crapped out on the way home tonight so I got to feel what the fuel cut feels like
Yeah I dont hit full boost in 1st or 2nd either. I need to log this and post up my results after I get the BCS sorted back out. I have to say that it is nice to finally deal with a professional car oriented(audio, performance, etc) shop. SGP is the real deal.
Old Nov 20, 2007 | 06:59 PM
athenG's Avatar
athenG
great #'s. how much boost do you get at 2nd? I think with a better Boost Controller you'll definitely hit full boost in the lower gears. So if you do a hard pull from 1st gear to 2nd gear you don't hit 8psi on second? I believe you have some TP and an aftermarket Ypipe right?
If i just slam my my pedal from a roll at 1st gear to 2nd then yeah I don't hit 8psi at 2nd. Try lunching your car around 2500rpm and I bet you hit full boost at 2nd. Also do you have a copy of the Dyno?
Old Nov 21, 2007 | 07:28 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Thanks. I really havent had a chance to fool around with the car or log anything. The tune is rock solid and the car is so much more fun to drive.
The only thing I need to do is mess with my boost map. I still have an overboost problem. I hit my fuel cut randomly. Other times it stays right at 8 psi.
I cant get the UTI logger program to log when I want it to so I need to play with that so more. Once I do that I well report what I hit in 1st and second gear.
Ill post something worth reading or looking at once Thanksgiving sorta cools down.
Old Nov 21, 2007 | 07:57 PM
  #38
athenG's Avatar
athenG
You are running on close loop rite? What is your boost cutoff? Well I have an Open Loop and with this colder weather I have hit 9.3 maybe ones but never hit my boost cutoff at 10psi ever. 95% of the time I'm around 8.6 and maybe went 8.9 a few times.
Old Nov 22, 2007 | 08:50 AM
  #39
Ahsmo's Avatar
Ahsmo
Imakecopies
Mark at SGP set it with Open Loop. My boost cutoff is 10psi. Mark said he saw a spike of 8.5 every so often but not consistantly. I am seriously considering bitting the bullet and picking up the high dollar electronic boost controller.
Old Nov 23, 2007 | 12:55 PM
  #40
Ahsmo's Avatar
Ahsmo
Imakecopies
Dyno Graph:
