Turbo XS BCS install: boost map needed
Old Nov 24, 2007 | 03:41 AM
  #41
QuadCam's Avatar
QuadCam
Originally Posted by Ahsmo
Mark at SGP set it with Open Loop. My boost cutoff is 10psi. Mark said he saw a spike of 8.5 every so often but not consistantly. I am seriously considering bitting the bullet and picking up the high dollar electronic boost controller.
use both ports on your wastegate, and then switch the boost tuning control to closed loop. It works fantastically!!! It's alot cheaper than a "high dollar" boost controller, and it's integrated with your ems. what more can you ask for?
Old Nov 24, 2007 | 03:55 AM
  #42
athenG's Avatar
athenG
At first I thought you were running close loop using the dual port. What did SGP said that you went with Open Loop? Were you running dual port with Open Loop?
Old Nov 24, 2007 | 12:12 PM
  #43
Ahsmo's Avatar
Ahsmo
Imakecopies
I am using both ports in open loop. I think I may switch over to closed loop as you said.
Thanks for the help guys.
Pleask
Dec 21, 2021 03:17 PM
codek
Sep 28, 2015 03:03 AM
