TXS Tuner won't record RPM ?
Old Nov 14, 2007 | 07:17 PM
bleunetizen's Avatar
bleunetizen
Default TXS Tuner won't record RPM ?
I have UTEC and Tuner.. ant I can get a log of A/F with rpm from UTEC's log but if I switch to Tuner display to look at Tuner's log, the RPM stays at zero?
Anyone got the same issue?
Maybe I should try disconnecting UTEC from Tuner and see if it will work properly then..
Old Nov 14, 2007 | 07:41 PM
gothchick's Avatar
gothchick
Disconnecting the tuner from utec would make the tuner a stand alone at that point (and it won't be able to see anything except AFR, no RPM)...
When I first connected mine together, my utec wouldn't see AFR, but the tuner did.... After awhile, the utec just started "seeing" the AFR from the tuner... Wierd. And has worked ever since.
So I guess my only advice is to just fiddle with it til it works. Remember the utec needs to be fully booted before the tuner comes on line... Or else they do wierd stuff like one not seeing RPM.
sherm
Apr 11, 2020 05:21 PM
Justin100
Nov 29, 2015 03:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
35reilly
Sep 28, 2015 07:42 AM
