Car wont go past 4k rpms???
Old Nov 17, 2007 | 06:30 AM
GolfinZ's Avatar
GolfinZ
Default Car wont go past 4k rpms???
Just finished up with my n20 install and when I was leaving the shop, I tried taking the car, (not while spraying thank goodness) past 4000 rpms in 5th gear and it wouldnt It felt like it was misfiring and felt like that was where the fuel cut/rev limiter was set to. The shop that did the install tapped the ecu when they wired the window switech (62 for throttle and 50 for tps). The car drives fine up to 4k because I drove 160 miles home after the install.
My ideas of sources of the proplem: 1) tapping the ecu 2) removing the intake tube (messed up the maf/throttlebody)
What could be the issues??
Old Nov 21, 2007 | 10:36 PM
!prjctmax!'s Avatar
!prjctmax!
The things that you have already stated and a "lean cut" as well
Old Nov 22, 2007 | 07:34 AM
GolfinZ's Avatar
GolfinZ
I found out the problem was the window switch; it was spraying fuel whenever the rpms reached the set activation point. By 4000 there was so much fuel that the ecu wouldnt let it rev past 4000.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
Calinismo350z
Sep 14, 2015 04:04 PM
