Has anyone re-dynoed weeks after dyno + tune?
Old Dec 23, 2007 | 04:40 PM
SniperHunter's Avatar
SniperHunter
Default Has anyone re-dynoed weeks after dyno + tune?
Someone mentioned that ECUs in the Z are self-learning, and that even with piggy-bank ECUs and the like, the OEM ECU will still correct all of the A/F settings and revert it all back to its original state. This person is someone who is extremely familiar with Nissan vehicles, so I didn't argue with him.
Nissan ECU learns the way you drive, and will counter AFC modifications to lean the a/f ratio, and obviously your car will run great on dyno day, but a few drives later your a/f will be pig rich back up top.
Another person said:
the newer z33 ECUs are like that.. u need to physically change the rom settings on the ECU chip. (Read only memory.. so hardcode the new a/f setting parameters and range, rev limit, and timing curves)
So would that make things like a reflash and a piggy back tune useless? Or are they completely wrong? Again, both are really well respected guys on another Nissan forum, so I figured I'd try to find some more info about this.
Has anyone ever done a tune and dyno, and gone back to re-dyno their car weeks later just to see if those numbers stuck?
Old Dec 23, 2007 | 06:54 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
When SGP tuned my UTEC, Mark inhibited the self learning stuff with the Cipher software.
So yes, I think the ECU will learn around the piggy back. I noticed that my car ran better the first time I turned the key than it did every day there after(before my tune).
Old Dec 23, 2007 | 11:40 PM
__jb's Avatar
__jb
Z + Rear Seat
I don't think you can disable any "learning stuff" with Cipher.
You can flash new targets with Osiris, though. That way the ECU learns towards your desired settings... or install a stand alone system that the ECU can not change.
Old Dec 24, 2007 | 05:53 AM
Nietzsche's Avatar
Nietzsche
My UTEC tune has stayed fairly consistant after 6 months. It varies a bit based on weather but is always right around were I left it.
Old Dec 24, 2007 | 07:49 AM
shawndon's Avatar
shawndon
So can the ECU override the UTEC?? My TS flash has stayed consistent as well. But sometimes it varies based on weather.
Old Dec 24, 2007 | 07:56 AM
athenG's Avatar
athenG
Are you FI? FI uses MAP and it has its own table for Fuel and Timing, how can the ECU interrupt when Utec is taking full control of your Fuel and Timing on load?
Old Dec 24, 2007 | 10:18 AM
shawndon's Avatar
shawndon
Me? I'm not FI. But I didn't know if the ECU had some way of going around the UTEC or not.
Old Dec 25, 2007 | 01:49 AM
Nietzsche's Avatar
Nietzsche
If you put the UTEC in open loop fueling it uses it's own base tables so there isn't a way for the ECU to override it.
Old Dec 25, 2007 | 05:55 AM
cox's Avatar
cox
+1
Old Dec 25, 2007 | 06:35 AM
shawndon's Avatar
shawndon
So even if you're not FI you can still use open loop??
Old Dec 25, 2007 | 07:27 AM
Jime's Avatar
Jime
Yes, only the MAP is recommended for FI only and I am even going to try that N/A. You also have to be in open loop to extend the rev limiter.
Old Dec 25, 2007 | 08:17 AM
shawndon's Avatar
shawndon
What about the timing?? I know most run 17 BTDC. Is that is that through the entire rpm range or does it vary by car?? I almost think I know the answer to this question.
Old Dec 25, 2007 | 08:21 AM
JETPILOT's Avatar
JETPILOT
The UTEC is not a pigggyback ECU. It is a parallel ECU.
JET
Old Dec 26, 2007 | 08:50 AM
SniperHunter
I'm inclined to believe that the ECU adjusts eventually to a mod. After I had the 5/16 installed, I felt a bit of a gain. But days later after about 100 miles of highway driving and some WOT, I noticed a much more notable gain - almost as if the spacer had been broken in. Traction became much looser in 1st and 2nd, where as before I had no such problems.
I had numerous people suggest to me that the Z's ECU simply learns to adjust to settings after some driving. I doubt it replaces a proper tune, but it's still nice to know that, allegedly, our ECU is always actively monitoring and adjusting.
Obadabot
Jun 18, 2023 11:31 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
