U-TECH, Bolt on's and Meth.......
Old Feb 3, 2008 | 01:41 PM
350Z400rwhp's Avatar
350Z400rwhp
Default U-TECH, Bolt on's and Meth.......
I may have to put my turbo kit purchase on hold for a bit as I am buying a house. After much research I have found that a U-TECH is a must have when going FI. I was thinking of buying a utech, a borla exhaust w/resonated dp's, and I already have a crawford manifold. Would I see any gains if I had a utech installed and tuned the car? I have heard a utech can add 10+ hp on a n/a car. What if I added meth and adjusted the timing etc. on a n/a car, would this yield any gains? I am mainly trying to do a few things to mod my car a little and hopefully most of these parts I can keep when I add a supercharger or turbo.
Old Feb 3, 2008 | 03:11 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
yes, a tuned utec will fully utilize the power those mods may offer.
Old Feb 6, 2008 | 01:59 AM
Ziggyrama's Avatar
Ziggyrama
Adding meth will certainly give you some good power. Are you going with 100% meth or 50/50 mix with water? Obviously, it will be even more beneficial with FI but once it's on and you're tuned, the benefits will be:
1. Much higher timing because of extra timing you'll be able to run on the car
2. Cleaner engine Alcohol will clean the internals and keep your engine running smooth.
Old Feb 6, 2008 | 06:50 AM
str8dum1's Avatar
str8dum1
also remember that if you are going to a tuner, it will be ~500$ for a based tune and a couple hundred dollars for a tune update. Make sure you have ALL your parts installed before you go in for a tune, otherwise it will get $$$ very quickly.
Old Feb 6, 2008 | 06:59 AM
06MagneticZ's Avatar
06MagneticZ
So water/meth injection on an N/A car will give you gains???
Old Feb 6, 2008 | 09:29 AM
gothchick's Avatar
gothchick
It will to the extent that it'll lower intake & cylinder temps and reduce knocking. I'd go with a 50/50 mix however. Pure meth will affect your AFR's requiring additional tuning to compensate.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
wanderingstuden
Jan 28, 2016 07:03 PM
