E-manage Ultimate ‎ Installation Help
Old Feb 24, 2008 | 11:05 AM
rk2334's Avatar
rk2334
Default E-manage Ultimate ‎ Installation Help
Hello Guys
I need help. I have bought used e-manage ultimate with sport harness when I ‎installed it and turned ignition on to start the engine did not run also Malfunction ‎Indicator Lamp (MIL) disappeared and fuel pump not working, only fans work. then I ‎removed e- manage harness and returned connection to normal position, still the problem is ‎same. Then I tried to reset ECM by turn key off and on sereval times hopelessly.
Any suggestions.‎
Thanks
Old Feb 24, 2008 | 01:10 PM
pmohr's Avatar
pmohr
Have you checked fuses to see if any were blown?
Old Feb 25, 2008 | 10:00 AM
rk2334's Avatar
rk2334
yes I did . All of the seems OK
Depravity
Oct 1, 2015 04:49 PM
