Utec fuel map interpolation
Old Mar 27, 2008 | 07:56 PM
MardiGrasMax's Avatar
MardiGrasMax
Default Utec fuel map interpolation
When calculating the needed injector pulse width does the UTEC use just the data in the particular load column you are in as it runs through the RPM range. Or does it use the data from the lower and higher load columns to average the final injector pulse width too?
Old Mar 27, 2008 | 11:26 PM
raditz's Avatar
raditz
As I understand, the UTEC interpolates between cells in the maps, but it doesn't in the temp compensation table
Old Mar 28, 2008 | 04:18 AM
MardiGrasMax
Thanks.
I thought about it more last night and I guess it would have to interpolate to between load points to be as smooth as possible.
Old Mar 28, 2008 | 09:52 AM
JonnyC's Avatar
JonnyC
Yeah, I really wish the temp compensation had more resolution along with interpolation. You would think that would be an easy thing to add through a software upgrade.
Old Mar 28, 2008 | 12:22 PM
str8dum1's Avatar
str8dum1
the better tuners (ie PF, FP etc) only use a small % increase with lower temps and dont touch higher temps. its really not that big of a deal.
2ndchanceZ
Oct 26, 2015 08:03 PM
