If I reset the ECU??
Old Apr 16, 2008 | 09:51 AM
RandyK1's Avatar
RandyK1
Default If I reset the ECU??
I put a Borla TD, MD spacer, Pop charger and Berk HFC's on my Z and I am thinking about reseting the ECU. My question is if I undo the battery for a few days to reset the ECU will my keys still start my car or will I have to reprogram for the key? I read something about the Z having a smart key and when you get a new key the car has to be programed for it. Will the car hold the key in memory or will it go bye bye when I reset the ECU?? Thanks
Old Apr 16, 2008 | 09:53 AM
Asian Invasian's Avatar
Asian Invasian
You should be fine..
Old Apr 16, 2008 | 01:54 PM
The Captain's Avatar
The Captain
I've reset my ECU twice and had no key problems.
You don't even need to leave the battery unplugged for a few days. I unplugged mine for about an hour or so while I installed my plenum spacer and that was enough to reset it. (You'll know once you get in the car and all your radio stations are gone.)
Old Apr 16, 2008 | 02:41 PM
CSF's Avatar
CSF
don't worry...your keys will still work.
i've reset my ECU a few times...no probs
Old Apr 16, 2008 | 02:53 PM
RandyK1's Avatar
RandyK1
Thanks for the replys. I just wanted to make sure before I did it. And atleast I didnt get any "What a stupid post" posts about my question so I dont feel so bad
Old Apr 16, 2008 | 02:54 PM
350ZTheStandard's Avatar
350ZTheStandard
what a stOOPid question, not a stOOpid post
Old Apr 16, 2008 | 03:00 PM
RandyK1's Avatar
RandyK1
Now I feel bad
Old Apr 16, 2008 | 03:03 PM
ec8931's Avatar
ec8931
dont mean to jack your thread, but what else besides radio station will reseting the ecu affect ?
Old Apr 17, 2008 | 06:38 AM
gothchick's Avatar
gothchick
The key code information (I believe) is stored in the BCM/BCU and is passed to the ECU for recognition when you try to start the car... If they don't match, the car doesn't start.
Old Apr 17, 2008 | 05:12 PM
jining's Avatar
jining
I believe you can reprogram keys but I dont believe the cars key code ever changes. You program the key to the code that your car has. The code will remain the same for your car, even if theres no battery.
I just started as a tech @ infiniti and that is what ive noticed so far with the keys. Dont quote me I might be wrong
Old Apr 30, 2008 | 01:51 PM
coolsd20's Avatar
coolsd20
Does anyone know how to reprogram a spare key? Thanks.
Old Apr 30, 2008 | 02:41 PM
OCG35's Avatar
OCG35
the radio stations have nothing to do with the ECU being reset... that’s just because the battery was disconnected.
You can disconnect the bat for a few seconds and the radio station preset will be gone - but it doesn’t mean the ECU was re-set...
Here's a quick ECU reset procedure:
ooops - posted wrong one... I'll have to find it.
Old May 1, 2008 | 07:38 AM
gothchick's Avatar
gothchick
To reset the ecu, just disconnect the battery and pump the brake a few times. Pumping the brake ensures the capacitor drains of all charge and resets the ecu...
I tried the "pedal" sequence procedure and never could get it to work right...
Old May 1, 2008 | 08:26 AM
OCG35's Avatar
OCG35
yeah, the pedal sequence is a PITA - you have to get the timing perfect...
the method you posted is actually the quickest and easiest... turn headlights on too - this helps drain the capacitor
Old May 17, 2008 | 02:24 PM
JJBLACKBEAST07's Avatar
JJBLACKBEAST07
whats the benefits from doing this?
Old Jun 2, 2008 | 10:51 AM
1Quick350z's Avatar
1Quick350z
I would also like to know the benifits..I have Strup headers MREV2 intake mani, 516" plenum spacer, Invidia exhaust, and UR Pulleys...will reseting my ECU do anything positive or make it worse.
Old Jun 2, 2008 | 11:03 AM
UpRev's Avatar
UpRev
Your ECU has learned it's setting through driving it around. It's going to have hit targets based on the last time it was reset and what all was done as far as bolt ons. If you add more parts, it's generally a good idea to reset any ECU so that it now learns as well as possible to cope with your new parts. That said, Nissan ECUs should be able to adjust themselves around most any bolt on part you add, so what gains you will make on the rev-up or newer cars with the wideband sensors will probably be negligible, but a general rule of thumb is that it is a good idea to do.
Old Jun 2, 2008 | 11:13 AM
1Quick350z's Avatar
1Quick350z
thanks for the quick response pimp..so u think I should do that brake thing? I have the touring model and it says that if i unplug my battery for too long my cd player has this KEY that i will need to input...I dont have service manual..will I lose my cd functionality?
Old Jun 2, 2008 | 11:14 AM
UpRev's Avatar
UpRev
The dealership should be able to get your that information. But I'd get it ahead of time to make sure.
Old Jun 2, 2008 | 11:24 AM
__jb's Avatar
__jb
Z + Rear Seat
Wouldn't it be cool if there was a software product that would let you program the ECU targets to a more performance oriented group of settings? Then you wouldn't have to worry about the ECU unlearning all your mods...
Oh, and you shouldn't have to take your ECU out of the car and mail it off for this service... You should be able to do it in your own garage... That would be cool!
