Osiris Tuner now available!
Old Oct 14, 2008 | 07:55 AM
WTX350Z's Avatar
WTX350Z
just to make sure, tuner version is still only good for one car correct?
Old Oct 14, 2008 | 08:04 AM
UpRev's Avatar
UpRev
Correct.
Old Oct 14, 2008 | 08:14 AM
SmallTuner's Avatar
SmallTuner
Originally Posted by UpRev
Basically yes. People keep asking for a base tune to build from and it's not a great idea. Start from the stock ROM and go from there.
The reason Tuners use a base tune on aftermarket stand alone ECUs is because they need to be able to make the car start, etc. The stock ROM already has that stuff in it, so theres no need for that with our system.
wow..... im dieing to see the stock timing map !!!
its gonna be really nice and easy to Retard timing correct on a FI car.
allso, engine respond gonna be much much faster and smoother.
By the way is timing VS KPA or MAF
i used to tune some LS1 engines using HP tune and i like the way it is
Old Oct 14, 2008 | 08:23 AM
UpRev's Avatar
UpRev
It's based off MAF, but it's a calculated theoretical adjustment based off it, not a direct relation. It looks up multiple tables to adjust timing, nothing is static.
Old Oct 14, 2008 | 12:59 PM
SmallTuner's Avatar
SmallTuner
is there any pics for the program, or any info about the car that ur working on ??? mods, boost, dyno graph.....
Old Nov 3, 2008 | 08:15 PM
black ghost Alt's Avatar
black ghost Alt
also, will the osiris work perfectly with vq35hr engines?
Old Nov 9, 2008 | 12:18 PM
bimmertech's Avatar
bimmertech
great product guys.
i am still operating on the beta version, i recently have been reading over my old info and have noticed there is a users guide.
i am not seeing this anywhere. i have run the installer a few times to see if i missed it, but i do not see it. there is no users guide in my uprev folder
do i need to "upgrade" my beta version to the regular version or am i just that blind?
Old Nov 10, 2008 | 09:42 AM
UpRev's Avatar
UpRev
Originally Posted by black ghost Alt
+1
Shortly we will have the HR support. Still working on making sure there aren't any issues with it when we release it.
Old Nov 10, 2008 | 09:43 AM
UpRev's Avatar
UpRev
Originally Posted by bimmertech
great product guys.
Upgrade it to the newest version and get the newest user guide also.
Old Nov 10, 2008 | 10:49 AM
black ghost Alt
Thats good to hear dude.
I hope you can finish it as soon as possible and consider me as a first buyer for the hr
Thanks
Old Nov 10, 2008 | 11:58 AM
UpRev's Avatar
UpRev
Thanks
Also if you're in Saudi Arabia you can work with Fahad at UAE Formula to get the right version for your ECU.
Rich-
Old Nov 12, 2008 | 08:53 AM
Netacoma2003's Avatar
Netacoma2003
MAF only reads to 5v per spec. Thats why the Modified MAF needs recalibration.
We provide a basic curve to start from when using the stock tube and Modified MAF with Osiris Tuner. You can adjust from there if you need to, or you can use an alternative MAF/tube and use our software to recalibrate it.
We just wanted an easy solution for our customers, something that works well, is reliable, and simple to duplicate.
Supposedly my Vortech kit makes 10psi but less than 400rwhp.....so would I need the Modified MAF or not?
Old Nov 12, 2008 | 09:10 AM
UpRev's Avatar
UpRev
You should be fine.
Old Nov 12, 2008 | 10:27 AM
athenG's Avatar
athenG
/\ so stock MAF can handle 10psi and power between 370-390whp? This is the first time I have heard that..
Old Nov 12, 2008 | 12:09 PM
str8dum1's Avatar
str8dum1
Mine maxes at 4500 rpms ~9psi
Old Nov 12, 2008 | 12:23 PM
UpRev's Avatar
UpRev
Depends on the car, we maxed one at 5v at just over 400hp. But obviously that guys chart shows his maxing out well before that.
psi does not equal hp, psi does not equal air flow, so it depends on the vehicle and application as to when the MAF runs out.
Which is why we have them available, if you need them, they have been made.
Old Nov 12, 2008 | 06:39 PM
str8dum1's Avatar
str8dum1
^^ much better answer than "You should be fine."
pretty sure MRC told Romey 'he should be fine'
Old Nov 13, 2008 | 06:19 AM
  #38
athenG's Avatar
athenG
Yeah my MAF also get maxed out past 4800rpm.. STS has a small turbo at it's just rated 50lbs/min which is the smallest out there for our car and my MAF also get maxed out after 4800rpm.
Look at this first gear pull and my MAF is already maxed out at 4psi and 5500rpm.
Code:
[TSMP][RPM][PSIG][MAF][TPS][LOD][KN][SIG][IDC%][IGN][VOEF][BMV][MMV][WBO2][AIT][CLT]
000.00 2953  +0.5 3.3   94   10   0  28.4  17.5 22.0 100 000  2.9  12.99 034  088
000.20 2443  +0.6 3.0   98   10   0  17.2  15.0 22.0 100 000  3.0  12.68 034  087
000.40 2442  +0.3 3.4  100   10   0  23.5  20.4 22.0 100 000  3.1  12.68 034  087
000.60 2761  +0.0 3.5  100   10   0  21.1  24.6 21.0 100 000  3.3  12.68 033  087
000.80 3039  +0.3 3.6  100   10   0  23.2  27.3 21.0 100 000  3.5  12.73 033  087
001.00 3421  +0.4 3.8  100   10   0  26.1  32.7 21.0 100 000  3.6  12.46 033  087
001.20 3836  +0.7 3.8  100   10   0  23.0  35.6 19.9 100 000  3.8  12.34 034  088
001.41 4234  +1.0 4.2  100   10   0  21.9  39.8 17.4 100 000  4.1  12.87 034  087
001.60 4658  +1.5 4.4  100   20   0  17.9  52.2 19.0 100 000  4.3  13.17 034  087
001.80 5096  +2.3 4.7  100   30   0  21.2  61.0 17.2 100 000  4.5  12.91 035  087
002.00 5553  +4.1 5.0  100   50   0  21.6  77.2 17.9 100 000  4.6  12.68 035  087
002.20 6018  +5.8 5.0  100   60   1  23.9  90.4 18.0 100 000  4.6  12.42 036  088
002.41 6574  -7.3 2.1    1    0   0  33.8  13.4 ECU  100 000  1.7  12.75 036  088
Now look at higher loading gear like 5th gear and I max out even sooner... 5psi and 3300rpm..
Code:
[RPM]   [PSIG]  [MAF]  [TPS]  [LOD]    [KN]     [SIG] [IDC%]    [IGN]    [VOEF]    [BMV]  [MMV]
2984	0.2	3.5	70	10	0	21.2	24	21	8	0	3.5
3015	0.7	3.7	69	10	0	20.2	24.1	21	8	0	3.4
3046	1.3	3.8	70	20	0	19.3	26.2	21	8	0	3.6
3079	1.9	3.7	68	20	0	21.3	29.1	21	8	0	3.8
3113	2.3	4	68	30	0	21.2	31.3	21	8	0	3.9
3150	3	3.8	67	30	0	21.2	33.9	20.7	8	0	3.7
3183	3.8	3.9	67	40	0	21.2	36.4	20	8	0	4.6
3232	4.4	4.4	67	50	0	20.1	37.7	18.9	8	0	4.6
3278	5.2	5	66	60	0	20.4	39.6	18.4	8	0	4
3333	5.7	4.8	67	60	0	20.2	42.5	18.2	8	0	4.1
3401	5.9	4.6	65	60	0	20	43.4	18.2	8	0	4.6
3445	6	5	66	60	0	19.2	43.1	18.4	8	0	4.6
3498	5.9	5	65	60	0	20.2	44.4	18.5	8	0	4.6
3549	5.9	5	65	60	0	19.1	44.9	18.5	8	0	4.6
3594	6	5	64	60	0	19.1	46.6	18.5	8	0	4.6
3638	6.1	5	54	50	0	20.2	47.1	19	8	0	4.6
Old Nov 14, 2008 | 08:34 PM
  #39
cdoxp800's Avatar
cdoxp800
You have Mail Rich
Old Jan 8, 2009 | 03:57 PM
  #40
UpRev's Avatar
UpRev
HR and VHR support are coming soon. Start contacting your local Pro Tuner.
