Does ECU Listen to Knock above 5000rpm?
Old Oct 23, 2008 | 07:00 AM
athenG's Avatar
athenG
Default Does ECU Listen to Knock above 5000rpm?
Can someone confirm to me if the stock ECU listen and pull timing above 5000rpm when knock is detected?
Old Oct 23, 2008 | 07:32 AM
gothchick's Avatar
gothchick
It does not listen for knock above 4000rpm, hence won't pull timing either.
Old Oct 23, 2008 | 07:52 AM
J. Dub's Avatar
J. Dub
How would you get knock if you were stock? I assume, TS, that you aren't?
Old Oct 23, 2008 | 08:36 AM
BERTO's Avatar
BERTO
running lean which causes more heat in the combustion chamber. Poor gas quality also. And Pre ignition spark.
Old Oct 23, 2008 | 09:30 AM
athenG's Avatar
athenG
So what happen to piggy back EMS like Ultimate, SS, Unichip that rely on the ECU to pull timing when detonating? That is scary then .... So how do you judge if you are getting false knock on the higher rpm with utec?
Old Oct 23, 2008 | 10:28 AM
gothchick's Avatar
gothchick
Let me check the FSM real quick to see if it says anything about ECU knock characteristics...
I can't speak for the other ems' out there; but for UTEC, I left the knock thresholds defaulted the way they were set from TXS, since their settings pretty conservative.
False Knock vs. Real Knock:
To preface - In Open Loop, UTEC does not rely on the ECU to detect or react to knock.
I don't consider an isolated (1) count knock to be real knock with UTEC. Isolated (1) counts can be mechanical noise, misinterpretation by UTEC, knock mic not calibrated finely enough, or a host of other things. If I get a (2) knock count or higher, or if I get a string of (1) counts, I consider those situations to be real knock, and adjust the tune accordingly. If the knock goes away in those trouble spots (which it always does in my case), that lets me know I had real knock. But a few random (1) counts here or there is not a big deal.
Old Oct 23, 2008 | 11:04 AM
gothchick's Avatar
gothchick
This is all I could find in the EC section of the FSM. Kinda vague...
Component Description NBS0007X
The knock sensor is attached to the cylinder block. It senses engine knocking using a piezoelectric element. A knocking vibration from the cylinder block is sensed as vibrational pressure. This pressure is converted into a voltage signal and sent to the ECM.
The knock sensor retard system is designed only for emergencies. The basic ignition timing is programmed within the anti-knocking zone, if recommended fuel is used under dry conditions. The retard system does not operate under normal driving conditions.
If engine knocking occurs, the knock sensor monitors the condition. The signal is transmitted to the ECM. The ECM retards the ignition timing to eliminate the knocking condition.
Old Oct 23, 2008 | 11:08 AM
gothchick's Avatar
gothchick
Not sure if this helps, but here's a pic.
Old Oct 23, 2008 | 11:27 AM
athenG's Avatar
athenG
The reason I'm asking is when I'm at the track (Drag) I knock like crazy but dont knock on the street. I do lots highway WOT race and tuning and never knock like this, every now and then I'll play with my Gtech and do some 1/4 pull and never knock.... I think I'll have have a more conservative tune for the track.. Anyways thanks for the info...
Old Oct 23, 2008 | 11:37 AM
gothchick's Avatar
gothchick
I bet you're knocking at the drag strip cause you're heat soaking while you're staging.
Meth/water injection, bigger rad, oil cooler, heat wrapping, venting, maybe a manual switch for your fans, etc would probably really help. Heck some guys will even put a bag of ice on top of their plenum when they're staging. lol~ :-)
Old Oct 23, 2008 | 12:02 PM
athenG's Avatar
athenG
It could be but not much.. My IAT is only around 25C-33C at full boost and ambient is about 10C.. I also kept my hood open and only close it when I'm about to go. I also have Water/Meth and tuned for it. I have a theory, most of my knock is just after I shifted to the next gear. I was able to solve some of the shift knock at the track by tuning my timing 0 column above 5000rpm. I think what is happening is that there is a delay just after I shifted and building boost and the delay before my meth kit start to spray again. I think I just need to richen up my A/F on my lower load column and higher rpm so that it is rich enough to accommodate for the delay on my meth spray...
Old Oct 24, 2008 | 07:04 AM
gothchick's Avatar
gothchick
Hmmm... Another thought I had; Is your Open to Closed Loop Delay set to "0"? If it's set to 1 or 2, that can cause shift flare, which could cause your Meth, shift, delay to get out of synch...
Old Oct 24, 2008 | 09:41 AM
athenG's Avatar
athenG
Mine is set to 0... I didn't really get to look at my logs closely at the track but now I think I found the culprit.. This past few weeks I had increased my meth from 40% to 50% meth and did my tune accordingly. I rarely (almost never) hit load 10-50 at above 6000rpm so I forgot to add more fuel above that.. I was speed shifting at the track and did a few power shifting and I noticed that most of the worst knock was when I powershifted... looking at the logs I'll be hitting load 10-50 at around 6000-7000rpm so my A/F was around 12.9-13.5 when knocking... It was stupid of me to left the higher rpm untouched coz I never hit them anyways... So right now I added more fuel at the higher RPM and lower loads so when I hit them next time I powershift I'll have ample of fuel.. I hit those load very quickly though coz I'll hit load 30 and it will jump straight to 60..
Here's one sample of my log..
You'll see I never really lifted my throttle all the way and when I shifted I hit load 20 then stratight to 60 were my A/F is lean..
Code:
[TSMP][RPM][PSIG][MAF][TPS][LOD][KN][SIG][IDC%][IGN][VOEF][BMV][MMV][WBO2][AIT][CLT][IGNT]
000.80 5101  +3.6 4.8   98   50   0  20.8  74.4 17.1  +5.0 000  4.6  12.19 016  086
001.00 5609  +6.0 5.0   96   70   0  22.8  89.0 17.9  +5.0 000  4.6  11.95 017  087
001.20 6100  +7.2 5.0   96   70   0  23.9  94.8 17.5  +5.0 000  4.6  11.83 018  087
001.40 6844  -2.8 3.8    0    0   0  25.8  65.6 ECU  100 000  2.2  11.89 019  088
001.59 6127 -11.4 2.0    1    0   0  33.8   6.5 ECU  100 000  4.1  12.49 018  087
001.80 6145  +0.8 4.5  100   20   0  16.0  54.9 19.2  +5.0 000  4.4  13.40 016  086
001.99 5575  +3.6 4.7  100   50   0  21.2  59.7 15.6  +5.0 000  4.4  13.18 018  087
002.20 5233  +5.8 4.7  100   70   0  03.1   74.7 15.1  +5.0 000  4.6  12.16 019  087
002.40 5189  +7.2 4.9  100   80   0  09.0   84.8 15.0  +5.0 000  4.6  11.64 018  087
002.59 5319  +7.5 5.0  100   80   0  14.0  89.9 15.4  +5.0 000  4.6  11.63 020  087
002.80 5528  +7.1 5.0  100   70   0  20.8  88.6 15.7  +3.0 000  4.6  11.66 020  087
003.00 5784  +6.9 5.0  100   70   0  22.9  89.3 17.0  +3.0 000  4.6  11.66 020  087
003.20 6038  +6.8 5.0  100   70   0  22.9  90.7 17.2  +3.0 000  4.6  11.67 021  088
003.40 6266  +6.8 5.0  100   70   0  23.7  91.6 17.0  +3.0 000  4.6  11.67 021  087
003.60 6513  +6.9 5.0  100   70   0  23.6  94.2 18.0  +3.0 000  4.6  11.66 022  088
003.80 7423  -7.2 2.9   55    0   1  42.8  72.0 ECU  100 000  2.2  12.29 023  088
004.00 7025  -4.0 4.0  100   20   3  34.0  51.1 24.1  +3.0 000  4.4  13.37 021  087
004.20 5959  +4.8 4.7  100   60  14  22.0  61.7 06.0  +3.0 000  4.5  12.96 022  088
004.40 5252  +7.0 4.9  100   80   0  20.7  79.1 13.8  +3.0 000  4.6  12.12 021  087
009.29 5180  +8.4 4.9  100   80   0  21.9  85.8 12.3  +3.0 000  4.6  11.44 024  088
009.33 5206  +8.1 5.0  100   80   0  21.1  87.5 13.4  +3.0 000  4.6  11.38 023  088
009.37 5258  +7.7 5.0  100   80   0  21.0  87.9 14.8  +3.0 000  4.6  11.39 024  088
009.40 5400  +7.1 5.0  100   70   0  21.8  87.5 15.2  +3.0 000  4.6  11.43 025  088
009.44 5528  +7.2 5.0  100   70   0  21.7  87.9 15.4  +3.0 000  4.6  11.51 025  088
009.47 5666  +7.3 5.0  100   70   0  22.9  89.1 15.1  +3.0 000  4.6  11.46 026  088
009.50 5799  +7.3 5.0  100   70   0  22.9  89.9 15.5  +3.0 000  4.6  11.40 026  088
009.52 5921  +7.3 5.0  100   70   0  23.8  90.2 15.9  +3.0 000  4.6  11.39 026  088
009.55 6052  +7.3 5.0  100   70   0  23.9  91.3 16.2  +3.0 000  4.6  11.38 026  088
009.58 6181  +7.3 5.0  100   70   0  23.9  92.4 16.0  +3.0 000  4.6  11.38 026  088
009.61 6263  +7.1 5.0  100   70   0  24.8  93.8 16.0  +3.0 000  4
Old Oct 24, 2008 | 12:13 PM
gothchick's Avatar
gothchick
Yikes. I see what you mean about that (14) count knock... That's pretty severe.
Cliff Notes:
TPS dips to 55%,
Load drops to 0%,
ECU takes over briefly,
AFR spikes up past 13,
Timing hits 24,
TPS goes back up to 100%,
You're already back in boost,
BAM - knock!
Strange. The UTEC transioned back to ECU Closed Loop. You were at 55% TPS @ 7000rpms... I wouldn't think it would transition back to Closed Loop or 0% Load in that split second... What is your TPS threshold set too?
Edit: Also - What gear was the shift knock in? I ask because I notice you had almost the same condition at the top of the log and no shift knock...
Edit to the Edit: I see the difference. You didn't have a timing spike at the top of the log, so maybe when it spiked towards the bottom of the log, that was enough to induce knock.
Another difference I see is that you're hitting boost sooner with the AFR/ Timing spike at the bottom of the log, because you didn't lift the throttle as much (only goes down to 55%).
On the bright side, UTEC was pretty good at detecting and reacting to the knock event. Pulled timing WAY back (from 24 to 6) in a split second~ :-)
Hopefully richening up those areas will eliminate the knock. I bet it will... Not much you can do about the timing spike since that was caused by the ECU.
Old Oct 24, 2008 | 12:39 PM
athenG's Avatar
athenG
The bottom log is when I powershifted from 2nd to 3rd gear.. I dont hit full boost on 2nd gear and that is why you see the boost build slower compare to 3rd gear were I usually hit full boost. I think the timing spike is a delay from Utec coz my timing map at load 20 and 7000rpm is about 17-18 deg. Anyways I may go back to Etown in 2 weeks so I'll see if it improves..
Edit: my Open Loop transition is 20 I think...
Old Oct 24, 2008 | 01:09 PM
gothchick's Avatar
gothchick
20? Is that TPS or RPM threshold?
TPS should ideally be set to 25
RPM should ideally be set to 20
But it all depends how your tune is set up, of course. :-)
Old Oct 24, 2008 | 01:12 PM
athenG's Avatar
athenG
I think my rpm is 1500 but I had to look at it again.. either way I'm definitely sure both are lower than 50 so I wonder why ECU took over..
Hey, I PM'ed you about Utec and NA tuning...
Old Oct 27, 2008 | 05:53 AM
gothchick's Avatar
gothchick
PM replied.
Old Oct 27, 2008 | 02:05 PM
frankie945's Avatar
frankie945
AthenG what size injectors are you using? I was checking out your log and with 600's I only hit the 50% column at 7.8 to 8.1 psi. Mid 8 psi I hit the 60% column. Hell last week I had a boost spike when it was about 45 degrees out, was logging at the time got 38 knock counts at 5200 rpms boost spiked to 12 psi and hit the 80% column. I think this utec has saved my motor twice now. In your other post you mentioned about the UPREV picking up knock I would like to know that as well.
Old Oct 27, 2008 | 04:16 PM
athenG's Avatar
athenG
I'm using only 440cc inj (Deatschwerks) so it is more 400cc You can see my IDC is around in the 90's% above 6000rpm. Check your "Map Min/Max value for Mapping" coz that will dictate what load you'll hit on certain boost. I have a feeling that you are set from 1-16psi and that is why you only hit 50% on 7-8psi. If you are only boosting 8 psi then I would set it from 1-10 psi, this way you still have 2 psi left in your load column just in case you overboost and set your overboost cutoff to 10psi. You are wasting precious resolution by spreading your load that far. I'm not that familiar with Orisis yet but if it just rely on the ECU to pull timing when knock is detected then it can be trouble since ECU dont monitor or wont react to knock past 5000rpm...
hulkout
Tuning
Sep 30, 2015 12:33 PM
speedsniper
Sep 14, 2015 08:46 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
