Rev Limiter
Old Nov 7, 2008 | 02:49 PM
carlos305's Avatar
carlos305
Default Rev Limiter
What is the highest safe rev limit for an 06 350z without cams?
Old Nov 8, 2008 | 06:48 AM
OCG35's Avatar
OCG35
"Safest" is what OEM is set at - 6700 for non-revup and 7200 (I think) for rev-up
You wont make power past OEM... there isn’t really a benefit to higher rev limit unless you have shorter gears and need the added rmp for fewer shifts (e.g. 1/4 mile drag) - or you have mods such as cams to make power past OEM limit... or you just like the added 200-300 rmp buffer for shifting near OEM redline.
For non-revup it has been determined (by TS and others) that OEM springs/rod bolts are good to 7200 – not suggested to go past that… I don’t know about rev-up.
Old Nov 8, 2008 | 06:52 AM
Push the rev limiter until the motor blows up, then back off 100 RPM.
Old Nov 9, 2008 | 11:42 AM
BiGGD198's Avatar
BiGGD198
^^^haha
no but in all seriousness....the non-revups dont mae any hp past 6200rpm and torque around that range either....so unless you want problems in the future, unless you get cams, valves, and springs/retainers....aka built heads....no point.
