Fuel management
Old Feb 3, 2009 | 09:39 AM
NVRacing's Avatar
NVRacing
Default Fuel management
I am looking into getting a fuel management system for my z. I would prefer to have a system for flashing the factory ecu. I am very familiar with tuning cars and flashing computers, but I havn't heard of any setups for the 350z.
If you guys could give me some links and your opinions that would be great.
The car has a turbonetics turbo on it, a sheet metal intake manifold, alcohol injection, a full exhaust, and a boost controller, I am looking to upgrade the fuel system to a return style with around 550 cc injectors, maybe a little larger.
Old Feb 3, 2009 | 09:53 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Feb 3, 2009 | 11:02 AM
UpRev's Avatar
UpRev
I'm sure that GT Motorsports and Injected Performance both have full fuel systems available to purchase that would fit your needs.
Depending on where you're located, either one of our Pro Tuners (listed on our site) or yourself can tune the car with our Osiris product.
Old Feb 4, 2009 | 08:33 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Assuming you are still using the stock motor, I would recommend some drop-in injectors such as the Deatschwerks 600cc 350z injectors. Don't worry about a return fuel system on the stock motor, it is not necessary until you are going for bigger power. If you are wanting an ecu flasher that you can tune your own car with, I would recommend Uprev's Osiris Tuner. Both of these items are in stock if you need.
Old Feb 4, 2009 | 09:53 AM
NVRacing's Avatar
NVRacing
Thanks for the help, I am planning to build a longblock for the car in the next year or so. When my muscle car project is done .
*edit* Is this osiris tuner capable of datalogging? And is the capture rate faster than a scan tool or comparable?
Old Feb 4, 2009 | 09:57 AM
UpRev's Avatar
UpRev
Yes, you can datalog using the Cipher cable, it reads at CAN BUS speeds, so as fast as the ECU can spit data out.
