Osiris Cranking Fuel Enrichment
Old May 12, 2009 | 06:46 PM
Madelinot's Avatar
Madelinot
Default Osiris Cranking Fuel Enrichment
Hi,
I just installed new 650 RC injectors. I also have a UTEC and the infamous hot starting issues. The stock Osiris table shows the following for the starting Fuel enrichment for each coolant range:
-40C, 113.6%
-20C, 105.9%
0C, 100.9%
20C, 94.9%
40C, 89.1%
60C, 83.9%
80C, 79.2%
100C, 75.2%
How is the table adjusted? What numbers would make sense to use and what's been proven to work?
Thanks!
Old May 13, 2009 | 04:21 PM
Madelinot's Avatar
Madelinot
OK, whatever. I guess nobody can answer. I just decided to play with the numbers; I lowered the -40C to around 105% and the 100C to about 25%. That has improved the hot starts quite a bit. I might lower it some more.
Old May 13, 2009 | 07:13 PM
BlinkerFluid's Avatar
BlinkerFluid
I left -40C, -20C, and 0C alone as I haven't gotten near to those temps. I'm sure when I get home I may have to modify them a bit.
Mine, as yours, are also considerably lower than what they are stock. I have DW 600cc injectors. IIRC 100C is in the ~20% range. From what I understand, you can also modify cranking fuel with the fuel compensation table and the 400RPM row.
Hope this helps.
Old May 13, 2009 | 07:43 PM
BrazenZ's Avatar
BrazenZ
Haltech has a similiar setup called cranking inj. rate and instead of #'s with % they have similiar size number like @ 84F / 115 ms. My Z is cold starting great but hot starts were a problem so I have lowered the #'s to 84F/ 115ms to 218F/45ms. The car hot starts much better.
Old May 16, 2009 | 12:30 AM
Emmanuel's Avatar
Emmanuel
UP REV ECU Flash and more! 350z/G35/Titan!
RT Tuning is NOW a Dealer and Pro Tuner for UPREV Engine Management. This New system is quickly becoming the go to system for 350Z/G35 Enthusiasts. Developed with cutting edge engine management in mind UPREV’S OSIRIS is at the forefront of the VQ and Titan V8 tuning market. Osiris also takes into consideration the needs of their customers providing 3 System levels to keep the customer tuned correctly as well as within their budget Once received, we will reprogram the ECU with a new file that is customized to your needs. Call us before shipping to verify processing time.
Parameters that we will tune include:
• Up to 5 Maps on cruise control equipped vehicles
• Idle RPM
• Speed Limiter
• Electronic Throttle Control to achieve Wide Open Throttle at all speeds.
• Rev Limiter
• DTC disable
• AFR Targets
• Fuel Compensation
• Ignition Timing Advance
• Cam Phasing for equipped vehicles.
OSIRIS STANDARD
Osiris Standard includes Cipher and utilizes the Cipher cable to reflash and communicate with the vehicle through the OBDII Diag Port. Osiris Standard also includes Map Switching allowing you to use different tunes for different situations and 3 eTune updates you can use at any time.
Osiris Standard is a licensed based system meaning your license will be transferred to the first ECU that is flashed. This vehicle can then be flashed as many times as the user wants, but the flash will not work on any different vehicles. One additional license can be purchased at a discount for enthusiasts that may have more than one vehicle, contact us for details.
• Idle RPM
• Speed Limiter
• Rev Limiter
• DTC disable
• AFR Targets
• Fuel Compensation
OSIRIS TUNER
The Osiris Tuner system includes Cipher, Map Switching, the flash utility and our powerful, new 2.0 ROM Editor. Osiris Tuner supports NA applications and high horse power forced induction vehicles. Using the an HPX MAF and 1000cc injectors we have tuned for over 550whp on the G35.
Osiris Tuner is a licensed based system. The purchase of Osiris Tuner includes one license that will be transferred to the first ECU that is flashed. This vehicle can then be flashed as many times as the user wants, but the flash will not work on any different vehicles.
Osiris Tuner does not include any base maps or eTunes, the user is expected to develop their own tune for their vehicle using the stock ROMS included in the software package.
Parameters that are supported in the ROM Editor include:
• Idle RPM
• Speed Limiter
• Rev Limiter
• DTC disable
• AFR Targets
• Fuel Compensation
• MAF transfer function
• Cranking Enrichment and Ignition Advance
• Injector Latency
• K Fuel Multiplier
• Intake Temp
• Calculated Load vs. RPM
• Minimum Effective Injector Pulse Width
____________________________________________________________ _____
Best Medicine for Acne Scars
First time home buyers tax credit
Old May 18, 2009 | 02:57 AM
Snow-G's Avatar
Snow-G
Can I go to an authorized tuner/dealer and have the base flash done? I already have a Utec and do not want to completely switch over at this point.
Old May 19, 2009 | 03:24 PM
__jb's Avatar
__jb
Z + Rear Seat
Lots of tuners flash the ECU when using a standalone.
Not sure if there are any tuners doing that on Mars however...
-jb
