given rwhp, approximate crank hp
Old May 23, 2009 | 08:14 PM
withagee's Avatar
withagee
Default given rwhp, approximate crank hp
Have had the car on jack stands for quite a few months adding parts here and there. Recently got the car tuned at Forged Performance.
The guys that knew I was working on the car also knew my goal was at least 400 rwhp. We got that...+
Lets say I'm making 400 rwhp based on the dyno sheet... Can a reasonable approximation of the crank hp be made given that number or is more information necessary? By "crank hp", I am referring to the hp numbers that car manufacturers specify.
Old May 23, 2009 | 09:19 PM
Parasitic loss of the drive train increases with speed, so figure between 5-17 percent. Multiply drive horsepower by 1.05 and 1.17. That's about 420-468 horsepower at the crank.
Old May 23, 2009 | 09:33 PM
freedonutss's Avatar
freedonutss
Forged performance utilizes a dyno dynamics which typically read lower than other dynos.
Old May 24, 2009 | 08:56 AM
withagee's Avatar
withagee
Wow. Really? Well... that sounds great if typically it reads lower than actual... would you know if that's the case? Love to find out I got a little more bang for my bucks.
Old May 24, 2009 | 09:05 AM
withagee's Avatar
withagee
Help me understand this in more familiar terms, please. Are you saying the drive train causes greater and greater hp loss at the wheels the faster you go? I don't have a clue but I'd like to learn. My first thought would be it would have less and less effect because momentum or inertia... see where I'm coming from?
thanks
Old May 24, 2009 | 09:54 AM
freedonutss
Yes that is the case, Dyno dynamics read lower than other dynos. Remember, a dyno is just numbers. What you can do at the track with the numbers is what really matters.
Live your life a quarter mile at a time, all the other bs doesnt matter. For those 10 seconds or less, your free.
Old May 24, 2009 | 11:19 AM
blazefast's Avatar
blazefast
I usually figure 10-15% for RWD, about 10 percent higher for AWD, and add a bit more if you have an automatic transmission, as the torque converter on a stock transmission gives you significant power loss.
It's hard to say exactly how much power you're losing, but what does it really matter? All the power in the world means nothing if you can't put it to the ground.
PS - SWAT came into my house, disrespected my whole family, because somebody narcd me out, and you know what? IT WAS YOU!
Old May 24, 2009 | 01:51 PM
withagee's Avatar
withagee
[QUOTE=blazefast;7361950] It's hard to say exactly how much power you're losing, but what does it really matter? All the power in the world means nothing if you can't put it to the ground. [QUOTE]
Just a metric I use in my overall strategy. Know your enemies (art of war). Good starting point for that would be manufacturer's claim of crank hp, no?
Next move is getting both rear wheels churning. I have a base model. Leaning towards Quaife. Understand it's a relatively simple install and have read good reviews. This should aid in getting all that power in my world to the ground.
PS - sorry about the whole SWAT thing... I was bored.
Old May 24, 2009 | 05:23 PM
BrazenZ's Avatar
BrazenZ
It's not that dyno dynamics reads lower, its that dynojet numbers are usually inflated.
Old May 24, 2009 | 05:39 PM
0jiggy0's Avatar
0jiggy0
It sounds like you need a number to brag to your friends. So why don't you just say 500hp who cares?
Old May 24, 2009 | 06:34 PM
withagee's Avatar
withagee
Brag? not hardly sport...... if I was the type maybe your familiar with I could just say "500hp" many thousands of dollars ago, right? I'll say 500hp when a reputable tuner like Sharif says the machine is there. I'm well past the age that I find it necessary to walk about with all muscles contracted. If you're smart you have goals; if you're wise you have strategies to reach those goals; if you're experienced you have metrics to measure your progress to your goals
Sounds like I care, huh? you bet your ride I do. Thanks for your input.
Old May 24, 2009 | 06:38 PM
withagee's Avatar
withagee
Interesting
350Z_Al
Oct 29, 2020 07:44 PM
foxsmp26
Sep 25, 2015 09:48 AM
Shane86
Sep 17, 2015 05:33 PM
