where is engine management located???
Old May 30, 2009 | 07:01 PM
350z-bra's Avatar
350z-bra
Question where is engine management located???
sorry for the nube question but i recently bought my z... and it's got some mods done to it and idk if it has any engine management (technosquare, uprev, ect..) where would it be if it were in the car so i can check???
thanks!
Old May 30, 2009 | 08:14 PM
rocks's Avatar
rocks
Inside your ECU you wouldn't be able to check.
Old May 30, 2009 | 08:15 PM
Spork's Avatar
Spork
Technosquare and uprev are reflashes. If anything, there would be a sticker.
Chebosto and others can confirm this.
Old May 30, 2009 | 08:41 PM
dieselmcore's Avatar
dieselmcore
if it has a unit like a motec m600 or sumthin or the greddy emanage or whatever, it will usually be somewhere around the passenger seat leg room, under the carpet or whatever... check there... if theres nothing, then u cant tell cause it could be a software thing without any hardware..
I hope this simple explanation helps...
Old May 30, 2009 | 09:16 PM
350z-bra's Avatar
350z-bra
ok cool thanks.. so what like send a pm with like the VIN or somthing?
Old May 30, 2009 | 11:47 PM
dieselmcore
why the vin?
Old May 31, 2009 | 10:43 AM
350z-bra's Avatar
350z-bra
Originally Posted by dieselmcore
why the vin?
how else could those people confirm if i have any thing or not?
Old May 31, 2009 | 05:43 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Technosquare puts a sticker on the ECU. The ECU is located under the dashboard on the passenger side. Poke your head under there and you can see the big black plastic connector.
If it's flashed with Osiris, (shop ECU flashed), then any UpRev pro dealer can plug in and check if the ECU has been licensed (flashed).
If you have a UTEC, FCON, HALTECH, or any other physical box, they are usually mounted under the passenger dashboard as well, or the passenger kick panel.
Old May 31, 2009 | 07:58 PM
350z-bra's Avatar
350z-bra
ok thanks a bunch!! that really helped. im going to check tomaro..hopefully there is something there
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Tochigi_236
Sep 27, 2015 03:40 PM
