Emanage Ultimate Problem with Throttle Position
Old Jun 9, 2009 | 01:24 PM
johnburm's Avatar
johnburm
Default Emanage Ultimate Problem with Throttle Position
Have a problem with the Emanage Ultimate reading the Throttle position at 100% with the ignition in the ON position without the car started. The car will crank but not start. I'm using Greddy's Plug-n-Play harness.
If I reconnect the the stock harness to the ECU without the emanage, it starts right up. When I reconnect the Greddy harness, it'll start the 1st time but not after that. The pull down tab for throttle parameter settings, shows that the "now" settings for voltage at 5.07v at 100%. When I try to clear the values, it resets back to the 5.07v 100%. Because of this, the car wont start due to no fuel. I'm at a loss at what is causing this. Spoke to Greddy and they have no idea other than it might be a bad harness or ultimate unit.
Any help would be appreciated.
Old Jun 12, 2009 | 01:51 PM
zguy825's Avatar
zguy825
Happy first post!
List mods first. Second if you do a search for throttle position reset you can reset your TPS and idle. Doing this would be the first step towards making it work.
Also you should check your tune. If you made a mistake on your fuel map your car will not start. Or if you made a mistake on your parameter settings your car will not start. It may not be just the TPS or voltage setting.
Who tuned your car?
Has it worked previously?
The more info the better. I have had many problems with me EMU but once I got it right its been working like a charm.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
