FI guys...What MAF's u running??
Old Sep 2, 2009 | 08:56 AM
mx594's Avatar
mx594
Related question:
I am building a custom turbo setup and I have a 3" pipe running from the hole in the radiator support to the throttle body. In this pipe I welded a flange to mount the stock MAF (so I no longer have to use the stock plastic housing). The stock housing is slightly tapered on the inside-it starts off around 2.875" ID and necks down to around 2.75" ID, then opens back up again to about 2.875". The 3" aluminum piping I am using has a 2.875" ID all the way through. Is this going to cause tuning problems? I have a UTEC, DW600's and a CJM RFS.
Old Sep 2, 2009 | 10:15 AM
Vince@R/TTuning's Avatar
Vince@R/TTuning
Vendor - Former Vendor
^^^ nah u should be good, just make sure the MAF is in the middle of a straight section of tubing where the air is less turbulent...
Old May 14, 2010 | 01:09 PM
Bigalow's Avatar
Bigalow
bump.
Vince,
I'm running the powerlab kit getting 326.9whp on dynodynamics. I'm running the UTEC now but my tuner will soon do an Osiris tune and told me that I'll need a HPX MAF sensor. You mentioned that 'drivability' will suffer? My Z is currently my DD. What should I expect?
Old May 14, 2010 | 01:14 PM
cdoxp800's Avatar
cdoxp800
Originally Posted by Vince@R/TTuning
Its not so much that you cant obtain good drivability, its that the PAS is overkill for most applications and were just looking to see how much power we can make on a stock maf. So far we have made 385 on a stock maf on a APS TT tuner kit. Hits just under 5v at 6800RPM.
Just wanted to see who out there is using what and what kinda power and if any, what issues they are having....
Well I am running the PMAS. My Stock MAF was hitting 5v at 4200 rpm with my HKS GT supercharger (stage 4).
Currently at 369HP, 336tq with AFR's at 11.6
Old May 14, 2010 | 01:31 PM
binder's Avatar
binder
i was on pmas vince.
hal was over 400hp on this with a mild tune before we decided to do the full standalone so i don't know what the full outcome of the pmas was going to be. prob the limit of my small vortech supercharger.
Old May 14, 2010 | 01:34 PM
jonnylaw's Avatar
jonnylaw
I run off of a map sensor to vpro. stock maf sensor is there to keep stock ecu happy.
Old May 14, 2010 | 01:43 PM
Vince@R/TTuning
yea, we have gotten pretty good with the PMAS MAF here. Its just that they are rated at 1000 HP and you start to lose a lil resolution. I was wondering if anybody experimented with some Ford or GM mafs that are rated for 500ish HP.
Old May 14, 2010 | 02:59 PM
Bigalow's Avatar
Bigalow
So how much is the stock MAF capable of holding? 400whp??
Old May 14, 2010 | 11:41 PM
ITOzann's Avatar
ITOzann
PMAS
Old May 15, 2010 | 07:28 AM
Vince@R/TTuning
The most i have been able to get out of a stock MAF is 385ish whp, and that was kinda pushing it to with no head room... That was on a APS Twin kit...
Old May 15, 2010 | 03:29 PM
maXmood's Avatar
maXmood
Under Boost!
in that case, everyone looking for +400whp must buy the HPX?
i myself is targetting 400whp with my FI setup..
Old May 15, 2010 | 06:30 PM
Vince@R/TTuning
^^^ thats kinda what i was gettin at with this thread. The PMAS MAF is over kill for 95% of the people using it. It would be nice if we had a 500WHP MAF that retained a lil more resoulution. Although these past couple months we have done really well with the PMAS MAF's...
Old May 15, 2010 | 07:55 PM
GT-ER's Avatar
GT-ER
I'm running a PMAS and it runs like the stock maf did, I have zero complaints. Vince gave me a base map and I massaged it a little to get it closer to spec but it behaves like the stock one.
Old Jul 5, 2011 | 07:41 PM
shakuya88's Avatar
shakuya88
Thread revival!
Dynoed today at 373 rwhp and maxed the maf at 5500rpm. Is there a magic way to get the PMAS to work right. I do exactly what the Osiris manual says and asked a few friends who have tuned before and none of us can get it to do anything right with the PMAS. Maybe mine is just defective?
350Z_Al
Oct 29, 2020 07:44 PM
