UTEC issues
Old Nov 21, 2009 | 02:22 PM
Hoooper's Avatar
Hoooper
Default UTEC issues
I recently installed a UTEC and im having an issue with the timing. The UTEC is not reading any timing, in the dashboard the display is a constant 0 degrees. My question is, what inputs does the UTEC use to determine timing?
Also, there is a connectivity reading between the crank sensor pin on the UTEC and pins 10 and 11, which are the VTC outputs I believe. I dont know if that is normal, but its a really small ohm reading so
sherm
Apr 11, 2020 05:21 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
350z82
Oct 1, 2015 06:25 PM
