Unique Problem - Bank 1 Overcorrecting (Rich)
Old Mar 26, 2011 | 05:36 AM
  #61
djamps's Avatar
djamps
If you've got antifoulers on your lower sensors, take them off... see my other thread. If you've got a true dual, make sure you've got a crossover or H pipe on it.
Old Mar 26, 2011 | 06:09 AM
  #62
binder's Avatar
binder
what thread?
I dont have antifowlers and it all goes into a single pipe to the turbo so no duals here...
Old Mar 26, 2011 | 08:24 AM
  #63
djamps's Avatar
djamps
Originally Posted by binder
what thread?
https://my350z.com/forum/tuning/5182...vs-tuning.html
I know it might not pertain exactly to you but it's more of a general statement for others in the same boat. Basically pointing out that the lower o2 sensors _are_ used for corrections.... When I had non foulers installed my ECU was adding fuel even though the upper widebands were showing rich. I would imagine a clogged cat or any kind of leak after the upper widebands would cause the same problem. Pulled the nonfoulers off and the A/F is now dead on 14.7 and no more overcorrection.
Old Mar 26, 2011 | 08:53 AM
  #64
Patrick250's Avatar
Patrick250
Default A Thought
From someone who has absolutely nothing to do with this issue since I have no mods at all. Just wasting time today reading and thinking about this problem.
At work we just built/shipped a fairly advanced machine that tests these A/F sensors performance to Bosch in SC. Neat stuff. It had a robot that loaded/unloaded the sensors 10 or 12 at a time, LabView running the tests.
Anyway, the thought occurred to me that maybe the ECU is screwing with the A/F correction intentionally as a test. Ramping the A/F up and down and charting the result. Is this plausible?
Old Mar 26, 2011 | 09:20 AM
  #65
kacz07's Avatar
kacz07
Originally Posted by onagao
I've just gone ahead and roughly chronicled the entire saga that hunting this gremlin has become - complete with point-by-point details of the problem and every major test that has been conducted with their subsequent results. It's all organized nicely in the attached Word document for anyone that is interested in helping me solve this problem.
I'm serious about this: I am going to give $200 to whoever successfully identifies what is causing all of this and leads me to the solution.
I will match that.
Old Mar 26, 2011 | 10:33 AM
  #66
djamps's Avatar
djamps
So has anyone logged the downstream sensor voltages while this is happening?
Old Mar 27, 2011 | 01:55 AM
  #67
binder's Avatar
binder
what is the channel name for those? I logged every CAN channel that haltech would allow me to log so i'm sure i have it somewhere.
also, mine would be difference since my haltech widebands are running the corrections and not the oem ecu like in your case so it probably doesn't apply to my situation.
Old Mar 27, 2011 | 05:20 AM
  #68
djamps's Avatar
djamps
Sensor 2 for both banks. The OP was dealing with stock ECU... haltech is a completely different animal, agreed... but one would think it wouldn't completely ignore the downstream o2 sensors. At least in the case of the stock ECU (or osiris flashed) the downstream sensors sometimes take priority for corrections.
Old Mar 29, 2011 | 10:54 AM
  #69
binder's Avatar
binder
ya, on the haltech the rear o2 sensors do nothing (as well as the fronts do nothing) except for keep the ecu happy. Ive had them out of the car with no issues except a CEL code.
Old Mar 29, 2011 | 11:44 AM
  #70
mgrotel's Avatar
mgrotel
have you swapped cats of the bad side?
Old Apr 1, 2011 | 04:33 PM
  #71
failsafe306's Avatar
failsafe306
My money is on a glitch in the ECU, like I told ya a year ago!
Old Apr 1, 2011 | 04:49 PM
  #72
laze1's Avatar
laze1
Can a bad wiring harness ground cause this problem?
( I have it also)
Old Apr 1, 2011 | 05:47 PM
  #73
failsafe306
( I have it also)
It is not causing THIS problem, but I suppose a bad or flaky ground could cause weird voltage reading.
Old Apr 1, 2011 | 07:12 PM
  #74
kacz07's Avatar
kacz07
That's an ambiguous statement. People have replaced the ECU to no avail. Something with the exhaust cam timing? Something with the UpRev programming codes not complete with the ECT?
Old Apr 2, 2011 | 02:15 PM
  #75
failsafe306
We logged cam phasing- not the issue.
Old Apr 9, 2011 | 07:07 AM
  #76
rcdash's Avatar
rcdash
Sensor 2 for both banks. The OP was dealing with stock ECU... At least in the case of the stock ECU (or osiris flashed) the downstream sensors sometimes take priority for corrections.
^ This seems to be a likely culprit if the latter statement is true. If there is a leak between the upstream and downstream O2 sensor and the stock ECU is correcting for it, then a rich O2 value may still result in overfueling.
Old Apr 22, 2011 | 12:51 PM
  #77
Zazz93's Avatar
Zazz93
How do that bank's plugs look? I've got a similar issue and noticed my plugs say the opposite to what code is being thrown (p1283 for 3 ultra rich plugs). I'm guessing there is something tricking the ECU to feel it can't dump enough fuel in to correct. I too have changed both O2's so I'm searching for a place that does leak testing (smoke machine).
Old May 13, 2011 | 05:08 PM
  #78
Tomci08's Avatar
Tomci08
I actually just got my car back after a retune and the code is now gone, passed emissions without a problem.
Old May 13, 2011 | 05:39 PM
  #79
kacz07's Avatar
kacz07
I was going to guess it was tune related before I even looked at this post.
After driving my car for a while, I think the car needs to be driven on the road or something. A steady driver on the dyno and the codes may not come up.
Loads vary, I don't think a dyno can replicate those situations.
Old May 14, 2011 | 08:41 PM
  #80
Tomci08's Avatar
Tomci08
i had the car tuned and then driven by the tuner for a few miles, then he decided to tune some more. After a few weeks he got the tune to the way he thought was good and after 60 or so miles of spirited driving i managed to pass emissions and now about 200 into it without any check engine lights. I would def say this is tune related.
