Wire harness help! Car wont start...
Old Dec 6, 2010 | 08:21 AM
350zion's Avatar
350zion
Professional
Default Wire harness help! Car wont start...
I was installing an aftermarket ecu today and while installing it had to make room in the passenger side foot well for the additional wiring. The car was running, while I unplugged a group of wires which led under the rug. When I did that the car shut off. I plugged it back in, but the car wont start. The aftermarket ecu was unplugged at the time and the factory ecu was running the car. I checked where the wires went and found out its a ground for the harness. Now the LED bulb on the dash stays solid when my key is in the ignition, and I crank it but it wont start. The wierd thing is that me and my cousin built an S14 w/ a VQ and we cant get it started due to which lloks like the same issue. Not 100% sure these problems are the same. Has anyone experienced this problem? Im looking for any ideas or thoughts you guys may have....
Old Dec 6, 2010 | 11:30 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Have you checked over your fuses yet to see if you blew anything? One box by the driver knee, and one in the engine bay behind the battery (under the plastic cowl).
Old Dec 6, 2010 | 12:48 PM
djamps's Avatar
djamps
Unplug the battery and let everything sit for an hour or two, reconnect and try again. You probably threw the ECU into failsafe mode. Worst case you fried the ECU.
Never, never plug/unplug engine/ECU wiring while the battery is connected. Much less while running...
Old Dec 6, 2010 | 01:21 PM
350zion's Avatar
350zion
Professional
Usually I'm good with disconnecting the battery, but I was freezing my *** off today, and my brain was in dumb mode. All I could think about was heat! I'm gonna check all the fuses Wen I get home later. Then do the battery disconnect if I find nothing.. As far as frying the ecu it would be a shame if this thing was that sensitive but I wouldn't be surprised.... Ill get back at ya later.
Thanks guys...
Ray
Old Dec 6, 2010 | 06:12 PM
raycs7's Avatar
raycs7
NATS
Old Dec 6, 2010 | 06:14 PM
Dynosty's Avatar
Dynosty
Originally Posted by raycs7
NATS
Doubtful. He told me the fans were kicking on when the key is on, which means the ecu is likely not receiving power. The first place I would look is the fuse box under the hood, under the plastic cover behind the battery.
Old Dec 6, 2010 | 06:46 PM
350zion's Avatar
350zion
Professional
I checked the fuse under the hood, no good! Ill check in the morning with a meter and better light as its dark out.
As for the NATS I hate that thing cause u never kno if thats ur issue. I have 2 other original keys which I checked out, and still the same outcome... I disconnected the battery for over night but I really do believe a fuse went. I just gotta figure it out...
Old Dec 7, 2010 | 04:14 AM
350zion's Avatar
350zion
Professional
Ok so today I get up and checked all fuses in both the battery compartment, and the drivers footwell.. None blown, Im leaning heavily toward the BCM locking out the ECU due to the fact that the damn red light is on solid. I believe the ECU is not getting power as Hal stated, the fans being on is a direct symptom of that, also because the Haltech wen plugged in isnt recognized by the lap top. I tried the steps in the FSM for ECU re-recognition and that didnt work...
Still open to ideas... Also attached are a few snaps of the ground wire I disconnected that started all of this....
Attached Thumbnails Wire harness help! Car wont start...-imag0042.jpg   Wire harness help! Car wont start...-imag0043.jpg
Old Dec 7, 2010 | 06:10 AM
str8dum1's Avatar
str8dum1
you checked the fuses behind the battery, correct? You have to pull the battery out to do this. Thats where the ECU fuse is.
no power is your problem, as i have had that exact same issue.
Old Dec 7, 2010 | 06:31 AM
350zion's Avatar
350zion
Professional
I didnt have to pull the battery out to get to the fuse box I pulled the plastic shroud and the wiper cowl out and took the cover off.. I checked the ECU IGN 10A fuse I believe and it was good...But definitely no power... Do you remember which fuse it was , The cover is marked for the fuse....
Old Dec 7, 2010 | 06:33 AM
str8dum1's Avatar
str8dum1
well if the fuses are fine, time to break out the multimeter, the service manual and start tracing leads for power.
Old Dec 7, 2010 | 07:51 AM
350zion's Avatar
350zion
Professional
All right heres where Im at. I pulled every fuse and visually inspected them and to no avail there was a blown fuse. Behind the battery fuse box top right row. 15a I pulled it and couldnt believe. I guess I missed it in the dark last night.. Lesson learned no more effin around at night in the cold..
The car is going to my shop in a few weeks to start the BP install. Im certainly not messin around with that in my back yard....
Thanks for all ur help fellas....
Old Apr 30, 2019 | 06:09 AM
@banggang850's Avatar
@banggang850
Default Fix?
Did you ever get this fixed?
Old Apr 30, 2019 | 06:23 AM
travlee's Avatar
travlee
Master
8.5 year dead thread, and op hasnt logged in for a year
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
SpartanZ32
Oct 22, 2015 09:36 AM
nissan1310
Oct 12, 2015 08:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
speedsniper
Sep 14, 2015 08:46 AM
