tuning at idle problems (aps 880cc with haltech)
Old Apr 23, 2011 | 10:35 AM
specialist's Avatar
specialist
Default tuning at idle problems (aps 880cc with haltech)
the engine temp is in the midle on the guage. When the car is at idle it dies when I try to lean it out to 13.7- 14.2arf. It seem to be ok when the arf is at 11 -12 that is a bit rich. i can't raise the rpm with the haltech.
Old Apr 23, 2011 | 03:35 PM
str8dum1's Avatar
str8dum1
are you using copy thru timing under vacuum? There are very few ppl that self tune Haltechs. I;m tryin to learn more myself.
Old Apr 23, 2011 | 04:21 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
my z idles great on 800ccs, bc stage 2 cams and haltech.
I set my low rpm vacuum settings to copy through and then tune the fuel tables. Be sure to set your latencies too.
Old Apr 25, 2011 | 09:56 AM
specialist's Avatar
specialist
Where is that? do you have a pic i don't see it the ecu manager?
Old Apr 25, 2011 | 10:10 AM
specialist's Avatar
specialist
The copy through setting is disable becuase i am using mass air flow setting is disabled. I have a air temp sensor.
Old Apr 25, 2011 | 10:14 AM
str8dum1's Avatar
str8dum1
you select the cells and hit "C"
Old Apr 25, 2011 | 10:51 AM
rcdash's Avatar
rcdash
You want to copy through timing, not MAF or fuel (both of which are possible with the Haltech). Well, MAF shouldn't effect anything anyway... (I presume you are a 6MT)
Old Apr 25, 2011 | 07:23 PM
deanfootlong's Avatar
deanfootlong
i can relate to what you're saying about idle afr's. currently i see 11.5-12.5 afrs at idle and thats what works best for me. make sure your injector dead times are set correct for the specific injector you are using. i played with copy through ignition timing for vacuum settings but found i got a lot of engine back fires and lean spots using that so i disabled it. and you are correct you can not adjust idle with haltech. though that would be nice.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
