stand alone or piggy back??
Old Jul 17, 2011 | 02:04 PM
Exemption's Avatar
Exemption
Default stand alone or piggy back??
im searching the forums as we speak for an answer to this question.
Im planning to go FI next year but as of now i plan to stay NA with full bolt ons.
Should i piggy back or get a standalone ecu?
which would benefit most on NA for now
Old Jul 17, 2011 | 03:24 PM
djamps's Avatar
djamps
Neither -- Osiris.
Old Jul 17, 2011 | 04:56 PM
Tricky-Ricky's Avatar
Tricky-Ricky
Although i would agree that Osiris is probably a good choice for basic N/A mods and low boost application's, if you are going to run a built engine with serious boost, i would go for a stand alone management, as the std knock control is not very good, and so as i have seen Osiris cannot re program knock control?
also i am reliably informed that it in fact doesn't listen after certain RPM in open loop, which would worry me should you encounter some bad fuel, most decent stand alone's have very comprehensive knock handling, and a lager map grid for all parameters.
Old Jul 17, 2011 | 06:41 PM
djamps's Avatar
djamps
You can extend knock control all the way to redline. That isn't an issue... if he plans to make more than 500whp down the road it might make sense to go with a standalone... but the extra cost and caveats of going that route wouldn't make sense unless big time FI was in his near future. For N/A and stock block F/I nothing beats Osiris in terms of feel and price point.
Old Jul 18, 2011 | 04:24 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
For normal NA upgrades, uprev is the easiest solution / best fit. It can also be made to work with mild forced induction. The best solution for forced induction is most definitely a standalone due to more precise/reliable tuning and safety features (such as overboost protection on a turbo setup) that the stock computer is not capable of.
Old Jul 18, 2011 | 05:36 AM
Exemption's Avatar
Exemption
Ok Thx for all the help guys. Ya the plan is a mild boost from super charging. I would assume that the stand alone would be a lot easier. However if osirus gives the best results for the Mula I shall read on !!!! Need to find an uprev spot
Old Jul 18, 2011 | 06:18 AM
djamps's Avatar
djamps
Standalone would not be simpler than uprev. Nothing is simpler than Uprev, which is basically just plug into the diag. port and start tuning. No parts to install, no wires to splice, nothing.
Since you're plans are for SC which isn't prone to overboosting like turbos, the features of a full standalone are way overkill. Just get Uprev'd from an Uprev pro-tuner shop and call it a day.
Old Jul 18, 2011 | 07:07 AM
Tricky-Ricky
Originally Posted by djamps
You can extend knock control all the way to redline. That isn't an issue....
Really! is this a recent development on the part of Up-rev? the tuners i have spoken to have always complained that this was an issue when wanting to go FI.
Old Jul 18, 2011 | 07:12 AM
Ruthless18x's Avatar
Ruthless18x
OP, what are your power goals? Are you going to track the car or just play in traffic?
Old Jul 18, 2011 | 07:47 AM
djamps's Avatar
djamps
not sure how long ago it was added, but you can log knock as well. To be honest anyone relying 100% on knock control is pushing the limits too much as it is. Even with (the old) 5k cutoff for knock control, a bad tank of gas or other mechanical issue will trigger the knock map far before 5k... the VQ knocks mostly in the 3-4k range. Not as much above 5k unless you've got a very serious issue.
Old Jul 18, 2011 | 09:33 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I'd spend the time and energy researching who will tune it over what they are tuning it with
Either can be made to work very, very well...or can be an absolute nightmare. It's all the hands of the person punching the keys
Old Jul 18, 2011 | 10:36 AM
Tricky-Ricky
Thats good to know and while in theory i agree with you, i would still rather have some decent knock control/fail safes when running higher boost in FI application's, no matter what the motor, or how well set up in the first place, it only takes a slightly clogged injector, or ott charge temps, or high EGTs to give rise to a bit of knock, and the intelligent knock control of the better ECUs like Syvecs and similar, can save a motor, as the danger area on a high boost motor is WOT as well as peak torque, IMEX most serious FI problems/failure's take place at high RPM and WOT.
Old Jul 18, 2011 | 11:25 AM
djamps's Avatar
djamps
Obviously nobody is recommending Osiris for big boost as it lacks more comprehensive F/I failsafes -- but still nothing that can't be added externally (J&S, ect). Anything over 500whp is standalone time in my opinion. There just isn't enough resolution in the boost areas.
Old Jul 18, 2011 | 07:54 PM
Exemption's Avatar
Exemption
i completely agree.
@Ruthless18x for show and some play in traffic. I go to a raceway near my city just do have some fun with friends on quarter miles. Few years down the road though the car will be tracking at laguna seca for some fun.
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
