350Z HR real power
DimTech dyno (Italian made)
Tuned by officiale UK Uprev seller (i take Osiris in UK because UK is in Eurporean law and economy) with 2 e-tunes ( now i have second step, first we log car, made one then log again and now i have these "final" maps)
7 "launches" and 7 IDENTICAL results, WITH or WITHOUT maps active...also this is strange....
Or the tuner "cheat" me (and doesn't seem so, the car go very well with tunes actives and cruise changes tunes, activating "vellet" on drop power correctly at 4000rpm as wanted for example) or also this fact is suspiciuos about dyno not able to get all the power...
does that dyno read low on other cars too?
im guessing its a combo of different things, looks like you are almost 1000ft above sea level, so that will affect it some, maybe the dyno reads low on other cars too. if the car feels good to you, then i wouldnt worry about it. its just a number and probably a result of certain settings on the dyno
edit: i just read the original post again and you mention that the dyno reads low on all cars, so i guess i dont understand the question here. im sure the car is fine and its the dyno.
Car with low power are quite similar to expected results, more power...more loss...
One 350Z 280hp "tuned", with a lot of changes (complete exaust, collectors, ECU programmed in Japan, airbox...) has on this dyno mda...210HP ! At MOTOR ! NOT whp !
The car goes not very well and may be has some problem (so they say...) but such a loose of power is suspiscius....
For that i ask about some numbers of dyno , just to be SURE about faulty dyno...
Thanks to all, i repeat the car is fast itself and with kat+tunes also FASTERRR but as usually better to check all !
Dyno numbers are just a gauge to see progress did you dyno stock ..? Like I said it doesn't matter the number just your overall gains ..my car made 430whp but performance at the track ie trap speed is a true gauge of HP
haha, yes , its actually not bad at all .. i just read your first post and was like WTF is this guy saying?
i thought it was the usual So-Cal-terrible-vietnamese-typing haha.
( now theyre all gna gang up on me haha ... JK GUYS!)
Never got into the whole FIFA thing over here tho.
I like our football better, i must say.
Anyways, good luck w the dyno issues etc ragazzi.
EnjukuRacing
Sep 11, 2015 08:30 AM
