What would cause lean condition?
Old Feb 5, 2012 | 02:56 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Originally Posted by kacz07
Failed cam sprocket assy. or sensor?
Where is that sensor, and how could I check it?
Old Feb 5, 2012 | 07:41 PM
mx594's Avatar
mx594
Did you try cleaning the MAF with MAF cleaner? What does your fuel pressure look like when this lean condition is occurring?
Old Feb 6, 2012 | 09:17 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
fuel pressure doesn't budge; it's around 42.5. I do have the JWT hack of boost controlled fuel pressure increase, so it increases just fine under boost, but holds rock steady on idle, or not in boost.
I'll clean the MAF today, just in case.
Old Feb 6, 2012 | 01:53 PM
0jiggy0's Avatar
0jiggy0
Have you confirmed no intake or upstream exhaust leaks?
Old Feb 6, 2012 | 01:57 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
No intake leaks; I still need to get to the bolts on the turbos to tighten those. I was not able to do so this weekend. I'm not saying they are loose, I just don't know right now, and I can't really get under my car right now. Have to wait until the weekend.
On another note, MAF is nice and clean, and no change. Oh well.
Old Feb 6, 2012 | 06:30 PM
kacz07's Avatar
kacz07
Std fuel pressure is 51-52 psi. Don't know much about that, though.
Old Feb 11, 2012 | 07:41 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Ok, so it turns out it also started throwing P1271. Due to this, I suspected a bad O2 sensor, passenger side, pre cat. So I just got done changing it out, problem fixed. PITA to do, though.
While I was down there, checked all the bolts on the turbos, they were all tight.
Problem fixed. Diagnosis: bad O2 sensor.
07ZEKE
Aug 23, 2021 09:15 PM
nanotech
Oct 2, 2015 05:02 AM
