Hesitation with boost peak (Osiris)
Old Sep 22, 2012 | 12:01 PM
lp_turbo's Avatar
lp_turbo
Default Hesitation with boost peak (Osiris)
Hi, i have G35 05 coupe with GTM stg2 tt kit, oem maf, stock block.
The car run fine & dyno curve are good but ont the street, when i have boost peak @ 8psi (WG set @ 6) the car hesitate 1sec...
-Timing is near to 55 in this range on Osiris timing map, I tried with 44 & less but still have this trouble...i can see timing fall to -1 degre & i see knock strenght when a datalog but i also tried to raise my High det. timing to the same value of low det. ...same thing..engine hesitate, timing fall for 1 sec ?
Any idea ?
Sorry for my english
Old Sep 23, 2012 | 11:04 AM
bmccann101's Avatar
bmccann101
how many hp are u pushing? ( ie how much wind are you making lol)
i ask because you said stock maf.
Old Sep 23, 2012 | 04:03 PM
lp_turbo's Avatar
lp_turbo
425hp 395lbs
According to GTM, the original maf is good even has 500HP with their setup
I thing oem piping is 2.75'' & GTM is 3'', need to readjust maf table? When i datalog, the trace line will never go to end of base fuel schedule table...
thx for the help!
Old Sep 23, 2012 | 04:09 PM
bmccann101's Avatar
bmccann101
I.just bought a new Maf at the recc of my tuner as he says they don't do well over 400 HP.
Old Sep 23, 2012 | 06:12 PM
djamps's Avatar
djamps
Chances are your MAF is maxing out did you log the voltage? I had a similar hesitation issue with PMAS that took zeroizing the fuel comp table and tuning entirely by MAF. Total PITA but it runs like a champ now.
Old Sep 23, 2012 | 06:38 PM
bmccann101's Avatar
bmccann101
Lol.. I'm.pretty proud to have guessed closely.
Old Sep 23, 2012 | 08:11 PM
lp_turbo's Avatar
lp_turbo
I'll datalog them tomorrow
GTM told me the oem maf should be ok up to 500hp.. I need to re tune oem maf or install a hpx?
Old Sep 24, 2012 | 05:53 AM
djamps's Avatar
djamps
If the MAF isn't maxing out (> 4.6volts) then I guess stay with it... but I've never seen much more than 400whp with OEM MAF without an enlarged housing, ect.
Old Sep 24, 2012 | 06:49 PM
lp_turbo's Avatar
lp_turbo
Your right guy's !
I maxed my maf... 5V @ 8psi.
Still have some questions..
-HPX or Uprev GT maf ?
-Idle bounce after engine start, tried to raise & remove some timing, still bounce..
-If i want check my log after saved them, i lose some sensor value...every value on maf sensor..V, GM/S, accel. ped. pos., inj duty..... normal ?
thx!
Old Sep 25, 2012 | 01:50 PM
djamps's Avatar
djamps
Your right guy's !
thx!
Either will be fine, but keep in mind you need a full retune after changing it out.
Idle bounce can be caused by a few things, usually tune related. I flattened my MAF table out a bit in the idle voltage areas to combat it.
Don't know about your last question.
Old Sep 26, 2012 | 10:41 AM
lp_turbo's Avatar
lp_turbo
Ok, thanks!
I ordered Uprev GT maf
For my idle bounce..i see in my datalog bank2 O2 sensor isn't stable like bank1 and correction bounce between 97-125% ...I'll order a new O2 sensor
kyin
Oct 15, 2015 05:54 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
codek
