Uprev maf tuning
Old Oct 15, 2012 | 04:09 PM
lp_turbo's Avatar
lp_turbo
Default Uprev maf tuning
I have already dyno tuned my car but i installed a gt uprev maf for some reason..so, i need a complet dyno retune or just retune compensation map ?
thx
Old Oct 16, 2012 | 07:52 AM
djamps's Avatar
djamps
thx
Both. Whole retune.
Old Oct 20, 2012 | 10:41 AM
lp_turbo's Avatar
lp_turbo
Ok, that influences also the timing map..? :S
Thanks
Old Oct 20, 2012 | 11:54 AM
tonyzS/C03's Avatar
tonyzS/C03
no it has no affect on the timing map, but will affect both your MAF table and fuel tables if i'm not mistaken.
Old Oct 25, 2012 | 06:14 AM
djamps's Avatar
djamps
You should recheck timing after adjusting fuel, because the ECU calculates actual timing based on the amount of fuel flowing. Remember, you're not plugging in actual timing numbers, you're plugging in 'burn time'. The ECU calculates actual timing based on the amount of time it would take X amount of fuel reach MBT. So changes to fueling WILL affect timing.
Old Oct 28, 2012 | 04:34 AM
tonyzS/C03's Avatar
tonyzS/C03
thank you for correcting me on that. This also makes sense to the values that are in the the timing maps as well, thanks.
2ndchanceZ
Oct 26, 2015 08:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
