AFR wb-b1 always to mutch high
Old Aug 23, 2013 | 12:45 AM
alexml's Avatar
alexml
Default AFR wb-b1 always to mutch high
why in the well my bank 1 is always high?
the bank 2 is smooth and stays in the target AFR but my bank 1 its always up and down.
I check the logs before and after fuel return system and is the same but just more accentuated.
What I’m doing wrong?
Is this big bank gaps normal?
vortech V3
injectors RC550
walbro + stage0 fuel return with rails at 6mm and sard RJ regulator
Old Aug 23, 2013 | 12:50 AM
alexml's Avatar
alexml
Its like this:
Afr wb-b1 afr wb-b2 target afr
15.71 14.66 14.7
13.70 14.58 14.7
14.06 14.56 14.7
15.30 14.62 14.7
17.05 14.64 14.7
17.61 14.62 14.7
14.25 14.62 14.7
13.87 14.66 14.7
13.23 14.66 14.7
13.07 14.60 14.7
13.04 14.58 14.7
12.90 14.50 14.7
12.84 14.46 14.7
13.17 14.46 14.7
13.29 14.46 14.7
13.09 14.48 14.7
13.71 14.44 14.7
14.44 14.44 14.7
17.00 14.42 14.7
17.29 14.48 14.7
14.30 14.48 14.7
15.80 14.52 14.7
16.65 14.58 14.7
15.48 14.60 14.7
17.42 14.66 14.7
15.71 14.66 14.7
18.32 14.79 14.7
19.81 14.91 14.7
21.28 14.91 14.7
21.28 14.76 14.7
18.82 14.76 14.7
14.25 14.97 14.7
14.04 14.97 14.7
12.91 14.97 14.7
12.49 14.76 14.7
Old Aug 23, 2013 | 07:24 PM
djamps's Avatar
djamps
Not normal.... mine are about the same closed loop and no more than 0.5 different closed loop (driver side / bank 1 will always be leaner with the OEM plenum).
Old Sep 3, 2013 | 08:21 AM
alexml's Avatar
alexml
thanks djanps
no one just tried to help me...
no problem
for future record i manage to solve the problem and it was on the 3 cilinder spark plug that was broken.
spark plugs changed and problem fixed.
thanks again DJANPS
Alexreyes
Sep 30, 2015 11:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
