View Poll Results: What would you do?
Bring it in to Dyno.
86.36%
Mail in your ECU
13.64%
Voters: 22. You may not vote on this poll
Dyno Vs Mail Osiris Tune
Old Jan 31, 2014 | 07:30 AM
Syner's Avatar
Syner
Originally Posted by pyshin
Those also don't exist for VQ35HR's. Learn something new every day. Good luck
I thought they did? Motordyne's site says the spacers can be installed on any VQ/Z/G - I assume you won't see any gains on the HR though?
Old Jan 31, 2014 | 07:37 AM
travlee's Avatar
travlee
Master
de only to my knowledge...
Old Jan 31, 2014 | 07:47 AM
Syner's Avatar
Syner
DE only gains, or DE only install?
Old Jan 31, 2014 | 07:51 AM
travlee's Avatar
travlee
Master
install.... our plenums are way diff, and actually plastic
Old Jan 31, 2014 | 07:53 AM
Syner's Avatar
Syner
I did not know this. Thanks
Old Jan 31, 2014 | 07:59 AM
travlee's Avatar
travlee
Master
hr plenum....
Old Jan 31, 2014 | 08:01 AM
pyshin's Avatar
pyshin
^ The infamous waffle-maker.
Old Jan 31, 2014 | 08:04 AM
Syner's Avatar
Syner
That's a huge difference! Disregard my earlier posts, the spacers definitely won't fit.
Old Jan 31, 2014 | 08:06 AM
travlee's Avatar
travlee
Master
but it does look like they make throttle body spacers for it
Old Jan 31, 2014 | 08:18 AM
seymore4's Avatar
seymore4
Professional
I would never recommend mailing in your ECU for a generic reflash unless you just need something simple like removing the speed limiter or raising the rev limiter.. but you can see good results with etuning-- you get your own cable to reflash and going back and forth with a tuner adjusting the tune with datalogs that you record while driving around. Still cheaper than a dyno tune and you get the cable so you can reflash back to stock and sell it used later on, reflash updates if you need any, as well do all kinds of OBD2 diagnostics like checking and clearing codes
Old Feb 3, 2014 | 08:31 PM
z33_hoonigan's Avatar
z33_hoonigan
dyno!!!!
Old Feb 5, 2014 | 11:07 PM
karletto66's Avatar
karletto66
If you can (me in Italy for example i had no choice, no tuner for this car and uprev software...) it's better DYNO for sure for clear reason, but also emailing it can be quite good if you use logs system and NOT a generic tune !
2ndchanceZ
Oct 26, 2015 08:03 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
