Reflash computer or not
Old May 18, 2014 | 07:53 AM
kenpla2's Avatar
kenpla2
Default Reflash computer or not
I installed a K&N cold air Air Cleaner assembly & need to know if I drop the battery negative for a minute, will this help the computer to relearn the air flow change ? If this does not help it to get the best performance for the change, then what should I do to get the best results ? Please give me some direction. thanks
Old May 18, 2014 | 08:00 AM
seymore4's Avatar
seymore4
Professional
If you've got $500 to spend then an Uprev tune will make a big difference
Old May 19, 2014 | 07:47 PM
l2frankie's Avatar
l2frankie
if an intake is all you got then dont even worry about it. i got borla exhaust/pop charger/kinetix hfc/ mrev2 + 5/16 spacer and running without a tune for right now
Old May 20, 2014 | 11:35 AM
Suwaidi's Avatar
Suwaidi
Get a tune after you're done with all your mods - will save you the cost of a retune.
http://www.uprev.com - locate a dealer. Will cost you about $525 to $650, including the cost of the license and initial tuning time. After that, re-tunes are based upon an hourly rate (generally $150 to $200). Since you're down in FL, look at S&R, ZFever and Z1Motorsports (GA).
Old May 20, 2014 | 11:42 AM
travlee's Avatar
travlee
Master
you are more than likely really lean then
Old May 23, 2014 | 07:57 PM
l2frankie's Avatar
l2frankie
oh forsure. sucks that my car feels alot slower at the very moment. i know i shouldnt WOT so i try to stay lower then 3k rpm. i would admit i do sometimes push my car a bit higher. i just dont got the money right now for a tune since i dropped it all into the stock market
Old May 28, 2014 | 11:25 AM
djamps's Avatar
djamps
Resetting the ECM is probably a good idea to try to get the fuel ratios back in check. Tune (reflash) would be ideal if you want more power of course.
Workshop12
Mar 23, 2020 01:45 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
